Chromolly Axle Kits - which is best?
ZONA
PostPosted: Fri Sep 02, 2005 3:40 pm    Post subject: Chromolly Axle Kits - which is best? Reply with quote
Rolled splines vs cut, you know the story.
Is there really any difference? Is there a leader in the axle upgrade market for the Dana 35 and Dana 30?
I've heard really good things about Superior Axle but others have said go Yukon. What's the difference really?
Thanks.
otisdog4
PostPosted: Fri Sep 02, 2005 7:35 pm    Post subject: Reply with quote
For the 30 I'd do Alloy USA. Unfortunately they don't make axles for a stock 35. Yukon is probably your best bet there. Alloy USA does a ten year warranty. The fronts come with 760 u-joints and full circle clips. I'm doing these front and rear on my 30/44.
You really should consider a Super 35 if you are gonna keep the 35.
http://www.4x4rockshop.com/scripts/prodList.asp?idCategory=153
Jim
03 sport, 4" mixed lift, D44/D30, 33's Blah Blah
