I put on bigger tires and...
NewKid
PostPosted: Fri Aug 05, 2005 5:23 pm    Post subject: I put on bigger tires and... Reply with quote
Ive lost power.
Duh.
I have an 99 TJ and i threw on a lift and 33's.
Do i need to regear? if so- what to?
Do i need to change ring and pinion?
Do i need to get an off-road chip or something?(do i even have a chip in my jeep?)
Thanks
PostPosted: Fri Aug 05, 2005 6:38 pm    Post subject: Reply with quote
Regear
you prolly have 3.07 gears like my friend stevo and he lost all his power
go 4.10 if its a daily driver and if its your off road warrior 4.56
PostPosted: Fri Aug 05, 2005 8:57 pm    Post subject: Reply with quote
Anytime you put on larger tires, your acceleration will suffer. Climb under and look for a metal tag on the diff cover bolts. If you don't know what ratio you already have, it'll tell you. If you're going to go to the expense of regearing, I would go with something more along the lines of 4.56's but it's your decision. http://jeephorizons.com/tech/rpmchart.html
PostPosted: Fri Aug 05, 2005 9:09 pm    Post subject: Reply with quote
Ditto. Re-gearing ain't cheap...if you have 3.07's you'll need to change the carrier too (if you've got 3.73's you can use the existing carrier). My call would be go 4.56...do it right the first time and forget it. 4.56 will work well with 33's on a daily driver. You'll have plenty of acceleration...and room to grow into 35's. Wink
My $0.02
NewKid
PostPosted: Fri Aug 05, 2005 10:14 pm    Post subject: Reply with quote
Awesome. Great info thanks.
should i bother with lockers in the back since im doing gears or wait till i get to the front with more money?
PostPosted: Fri Aug 05, 2005 10:17 pm    Post subject: Reply with quote
I'd do the lockers at the same time - save yourself some cash. Wink
PostPosted: Fri Aug 05, 2005 10:20 pm    Post subject: Reply with quote
Depends on the locker. A Detroit or ARB will require the gears be setup. So you might as well have it installed during the re-gear. If you are going with a lunchbox style, those can be installed anytime.
sidehill
PostPosted: Sat Sep 10, 2005 9:11 am    Post subject: Reply with quote
4.56 gears & 33's work well.
