Antenna questions
IBTJn
PostPosted: Sat Sep 24, 2005 4:03 pm    Post subject: Reply with quote
I tune my antennas for channels 1 and 40. If it's higher on 40 than on 1, I need to shorten the antenna. If it's higher on 1 than 40 I need to lengthen it. Doing this will typically get me perfect SWR's in the middle of the band.
As far as the cap making a difference, it's a Firestik thing. None of the antennas I have (Francis, Tigers, etc.) that use a cap have that problem. Everyone I've heard talk about that say it's normal. If you've been shortening the antenna (which would be my guess) shorten it some more and see what happens. The Firestiks I've tuned I always put the cap back on prior to checking SWR's. I've always been able to get them flat (even with some side reflection)...so keep working with it.
Wink
Stevo02TJ
PostPosted: Sun Sep 25, 2005 12:20 pm    Post subject: Reply with quote
Thanks! I've checked it about 20 times each time I hook the SWR up to it, and it never goes below 1.4 when the cap is on...no matter how high or low the little screw in the top is.
IBTJn
PostPosted: Mon Sep 26, 2005 11:39 am    Post subject: Reply with quote
Huh. ??? Well I'd wonder if some side reflection or something else might be causing that. But nevertheless, a 1.4 SWR is acceptable. I'd leave it if it were me.
Wink
PostPosted: Mon Sep 26, 2005 6:27 pm    Post subject: Reply with quote
whats the ideal setup everyone is after?
IBTJn
PostPosted: Mon Sep 26, 2005 9:30 pm    Post subject: Reply with quote
As far as SWR's, 1.1:1 but 1.5:1 or under is acceptable...at least IMO.
Is that what you are asking? ???
PostPosted: Mon Sep 26, 2005 9:49 pm    Post subject: Reply with quote
Ideally speaking you would want an SWR of 1 to 1, meaning absolutley no power loss during transmission. Nice in theory, almost impossible in practice. Practically speaking, like IBTJn said, anything under 1.5 to 1 is acceptable...but the lower the better.
PostPosted: Tue Sep 27, 2005 7:41 am    Post subject: Reply with quote
thank you thats what i was asking...so what happens when you have power loss in transmission? what exactly does that do?
PostPosted: Tue Sep 27, 2005 7:25 pm    Post subject: Reply with quote
um...you get less power transmitting from the antenna then the radio is putting out? In cases of high SWR, that can actually damage the radio.
It should also be pointed out that transmission vs. reception are two completley different animals. Hearing someone from miles away means absolutley nothing about how your system is tuned...it's whether they can hear you from that distance that matters..
PostPosted: Wed Sep 28, 2005 6:22 pm    Post subject: Reply with quote
on my cb when people talk most of the time its full of static and hard to make out what they say and even when people dont talk i get a lot of static...i change my squelch and then i dont hear anything not even people talking....
basically i have to constantly move the squelch and people only come in clear if they are REALLY close like 2 miles or under
any suggestions?
PostPosted: Wed Sep 28, 2005 6:55 pm    Post subject: Reply with quote
Do you have a noise filter on the power line? You'd be surpirsed how much of the static is generated by the ignition, alternator, etc.
I don't touch my squelch...I leave it turned all the way up (to let the radio gather up everything) and use the RF gain to cut back the static. I find that I pick up more transmissions that way and it makes the radio much more "hands off".
PostPosted: Thu Sep 29, 2005 4:32 am    Post subject: Reply with quote
i dont have a noise limiter where do i get one?
yea i can hear all kinds of noise through the cb, even the door ajar buzzer
PostPosted: Thu Sep 29, 2005 5:44 am    Post subject: Reply with quote
Radio Shack has a power line filter that goes between the hot line and whatever you attach it to, battery terminal, fusebox, etc. Simply pull the red wire off the power source and attach the noise box on the end of that, and its wire to the power source. Most filters also share the ground plug, although I can't remember if mine has one on it or not.
Bottom line: pathetically easy to mount and install, makes a WORLD of difference to your signal reception. Anything that causes feedback to your CB, i.e. turn signals, power locks/windows, etc..., will be smoothed out of the line to the CB, clearing up your reception. A worthwile investment. thumbs
PostPosted: Thu Sep 29, 2005 7:13 am    Post subject: Reply with quote
about how much do they run? and i have the radio shack cb like stevo is that a good cb or is there a better inexpensive cb i should get?
i drive back and forth to school at blue ridge so im on 81 everyday and i use it when i go wheeling
PostPosted: Thu Sep 29, 2005 7:48 am    Post subject: Reply with quote
Lower end ~ $15 - $20
Higher end ~ $45 - $50
I think the RShack is like $15. Low end does a good job of filtering, and obviously higher end does even more.
As far as the Realistic brand, it's pretty much a knock-off of Uniden and Cobra units, so it works fine for what you need. You ain't flyin' down 'de hi-way wit' 18-wheels a hummin', so it'll do you just fine.
PostPosted: Thu Sep 29, 2005 8:19 am    Post subject: Reply with quote
k ill pick one up 50 bucks is a lot of money for my cb seeing as how i dont use it all the time thanks
Page 2 of 3
