4WD Switch
bhudda28
PostPosted: Wed Sep 21, 2005 10:35 pm    Post subject: 4WD Switch Reply with quote
I have a '95 Jeep Grand Cherokee w/ 249 transfer case. Does anyone know where the 4WD switch is located. I want to replace it and I already have the part (if its the right one!!!) Are there any wires running to this switch or a hose maybe? Because the only wire that I see on the transfer case leads to something that does not match up with the part!!!
cajzmere
PostPosted: Sat Sep 24, 2005 3:48 pm    Post subject: Reply with quote
should be above the shift mechanism, does have 2 wires coming out of it. It's a screw in thing, almost looks like a 02 sensor but has a spring loaded "feeler" thing on the bottom end. Had to change mine when I switched from 249 to 242.
