Radiator leaking
robt46
PostPosted: Fri Sep 23, 2005 2:19 pm    Post subject: Radiator leaking Reply with quote
Hi, my first post. I got a 2000 Cherokee Sport. And spung a leak in the radiator. Decided to install one. My question, is there any advise on changing it. I mean anything that might give me trouble. I was told that the trans lines are a little different. Something about one is a pull apart type.??? I guess that refers to like a A/C line connection or something. Anyway if anybody has any advise I'd appreciate it. Thanks Robt.
robt46
PostPosted: Sat Sep 24, 2005 7:16 am    Post subject: up grading cooling. Reply with quote
Not getting to many responses. Decided to do the upgrade in the tech post. While I'm changing the radiator- might as well. The only thing giving me trouble is disconnecting the lower trans cooling line. Must be some kind of disconnect other than unbolting. Anybody familiar with this. Sure would appreciate some advise. Thanks Robt.
GREATONES96
PostPosted: Sat Sep 24, 2005 11:30 am    Post subject: Reply with quote
Were you see the tranny line plugs into eachother there is a tool thats slides in to release them, you can purchase the tool from a local auto shop like checker or auto zone. Let the guys at the counter know what it is you are doing and they will know what tool it is you need.
robt46
PostPosted: Sat Sep 24, 2005 1:42 pm    Post subject: Leaking Radiator Reply with quote
Hey thanks for the comeback. I have the set of release tools although I never used them on the trans lines. Only fuel lines. The coupler to flex has no tabs to push in. The tool does,nt have anything to push against. Crazy huh. Like to find somone who used them on this year and model mabe they changed things. Anyway I'm gonna look at it some more mabe I'm doing it wrong. Robt.
robt46
PostPosted: Sun Sep 25, 2005 5:17 pm    Post subject: Leaking radiator Reply with quote
Well I finally figured the dissconnect on the flex return line. If anybody tells you there's rubber tabs you push in with a release tool. Better look closer. On my Cherokee the coupling had the release tabs inside the fitting. And they were metal tabs holding the tube in. This got gunked up so bad it looked like it was molded that way. I had to chisel, soak in WD40 blow out and clean out behind the tabs to insert the release tool.So watch out it may not be a 5 min. job. Took me a while. Also mine was in a bad place . No room to work on it. Everything else was cake compared to this. Robt.
