Jeep AC working wierd
jefferywilson1980
PostPosted: Sat Sep 24, 2005 5:20 am    Post subject: Jeep AC working wierd Reply with quote
I recently bought a 98 Jeep Grand Cherokee and the AC will blowing out
the vents until i push the gas then it will change to what seems like the
defroster i think it is a sensor that is going bad but i dont know which one
it is also the gas milage is going down drastically and it is over heating
even though i have changed the thermostat fan clutch flushed the system
any help would be greatly apperciated
Jeffery Wilson
Kirk715
PostPosted: Tue Nov 01, 2005 9:45 pm    Post subject: Grand Cherokee A/C weirdness & overheating Reply with quote
Hi - I too have had A/C problems that when I go up a hill especially at higher speeds, the A/C starts blowing out the defroster vent. The dealer is skeptical that I have a problem. It usually goes away when the car levels out or power drops. I have to believe that it is a loose vent cover that the angle of the car will set off in combination with the airflow. I just figure it is not worth spending money on.
Re; Overheating - I went to a lower pressure radiator cap. I think the original specs call for 18 psi, but I have been using 13 psi with fine results. I think the higher psi was preventing the thermostat from functioning. I was getting overheating in the engine with cold water/fluid still iin the radiator.
