wheel studs
el_dubya
PostPosted: Tue Sep 27, 2005 12:49 pm    Post subject: wheel studs Reply with quote
I took off my wheels today to do some cleaning/painting on the frame behind them. All the lug nuts were extremely tight, I almost had to stand on my breaker bar to get them to loosen. Once I got them off I put a little oil on the studs and put it back on. All was well... until the last one. It never loosened, just stayed tight while I turned it. I figured it was turning the stud or getting ready to twist off, it twisted off. I figured better now in the garage than later on the road/trail. I have the factory drum brakes. I went to quadratec to see if they had parts, I found the oem chrome lug nuts, $1.49 everybody else wanted $10+. When I searched for wheel studs it came up with 4 results. No description on any of them. The part numbers were 52428 followed by 00 02 03 and 04. Which one do I need? It is the passenger side rear wheel. I have a '98 TJ with stock brakes. Also, are these pressed in or are they something I can install easily without a press? And one last thing. To remove the drum I just take off those spring clips on the studs and pull the drum off? Thanks guys.
Dub
KnightFire
PostPosted: Tue Sep 27, 2005 5:11 pm    Post subject: Reply with quote
Can only answer one question for ya, if they are press in studs, you don't really need a press, even though it's nice to have.
You can simply sacrifice a lug nut with large steel washers, use a impact gun, the lug nut and washers to draw the stud into place. I've done it several times...works like a champ.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
Keithtj
ARLI$$
ARLI$$
PostPosted: Tue Sep 27, 2005 7:57 pm    Post subject: Reply with quote
I threw a stud on my jeep and had my tire place put on in. It cost me $10 and I didn't have to worry about it.
My Morning Jacket
