Re-geared with 33-inch tires?
guesswho369
PostPosted: Wed Sep 21, 2005 10:40 am    Post subject: Re-geared with 33-inch tires? Reply with quote
I bought this jeep with 33-inchers and am wondering how I can tell whether it's been re-geared or not? I know the speedo wasn't changed, but my GPS tells me I'm doing 65 at 2500 RPMs (5spd 4-cyl 97 TJ). Does anyone have factory gearing with 33-inchers?
PostPosted: Wed Sep 21, 2005 1:02 pm    Post subject: Reply with quote
What gear are you in?
guesswho369
PostPosted: Wed Sep 21, 2005 1:05 pm    Post subject: Reply with quote
5th gear
PostPosted: Wed Sep 21, 2005 1:27 pm    Post subject: Reply with quote
AX-5 has a final drive ratio of 0.79.
With 4.10s, 33s, and 2500rpm, you should be travelling roughly 75mph.
With 4.56s, 33s, and 2500rpm, you should be travelling roughly 68mph.
With 4.88s, 33s, and 2500rpm, you should be travelling roughly 63mph.
To get a definitive answer, I'd recommend pulling a diff cover or both and counting the ring and pinion teeth. Divide ring teeth by pinion teeth and you'll have the gear ratio. I've seen the gear ratio stamped into the outside edge of the ring gear, also.
guesswho369
PostPosted: Wed Sep 21, 2005 1:35 pm    Post subject: Reply with quote
Thanks - I'm going to have to crack the case I think to figure out for sure, but by your chart it sounds like I've got 4.56. You think there'd be any problem downsizing to 31-inchers maintaining that ger ratio?
PostPosted: Wed Sep 21, 2005 3:57 pm    Post subject: Reply with quote
No...with the 4banger, that's probably a more suitable tire size with that gear ratio.
guesswho369
PostPosted: Thu Sep 22, 2005 6:15 am    Post subject: Reply with quote
That's what I was hoping you'd say - I have to firewall the pedal to maintain 65 on a gentle incline or with a slight headwind.
THANKS!
T.O.W. Vehicle
PostPosted: Thu Oct 13, 2005 2:58 pm    Post subject: Reply with quote
If you're floored and running 65 in fifth I want to guess your on 3.73 or maybe 3.07 gears. With 33" tires my guess is 3.73
I had 3.07 gears with 31" tires and was almost powerless at 65. I regeared to 4.10 and increased my tire size to 33"s and now have my power back in higher gears.
Borrow a GPS unit and dtermine your actual speed or measure a mile and time it out.
"T.O.W. "= Tent On Wheels.
Best Top Sailcloth RAT
RE 4.5"Super Flex Lift
AA HD SYE
JKS Quicker Disconnects
Shrockguards
PostPosted: Thu Oct 13, 2005 4:47 pm    Post subject: Reply with quote
He's got a 4cyl 5-speed. It's got 4.10s already.
T.O.W. Vehicle
PostPosted: Fri Oct 14, 2005 4:10 am    Post subject: Reply with quote
My BUST Thanks!
AA HD SYE
Shrockguards
