Error - NO BUS
Ra
PostPosted: Wed Oct 12, 2005 1:51 pm    Post subject: Error - NO BUS Reply with quote
Could errors like this: (travelling at about 80kms, notice the NO BUS error and orange engine light error. Speedo and tacho dead) Sorry about the pic size.
be caused by this?:
Whats the best way to clean this battery terminal?
Cheers,
PostPosted: Wed Oct 12, 2005 2:34 pm    Post subject: Reply with quote
Get a battery terminal brush and some of the spray that's used to prevent the corrosion from occuring. Check out any local auto parts store.
KnightFire
PostPosted: Thu Oct 13, 2005 12:58 am    Post subject: Reply with quote
Put some dielectic grease on those terminals after cleaning.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
Black2001TJ
Leopard Skin
Leopard Skin
PostPosted: Thu Oct 13, 2005 5:12 am    Post subject: Reply with quote
As for the No Bus part, what year is your Jeep? I doubt it's related to the battery terminal, but yes, you need to clean that!
Try pushing on the center of your display where it says No Bus to see if you can get the connector to seat. It's most likely a loose connection from what I remember, but I could be wrong. Good luck, keep us posted.
Docjim
PostPosted: Mon Nov 07, 2005 10:10 am    Post subject: Reply with quote
My Jeep did the same thing a few weeks ago. It would come and go. My mechanic pulled the console and couldn't find anything, but when he put it back it stopped the problem. He figured it was a loose connection and he tightened everything he could. The problem has not returned.
KnightFire
PostPosted: Mon Nov 07, 2005 6:15 pm    Post subject: Reply with quote
Yep, pretty typical problem on the Jeeps and Neons, dunno why, just is. A good fix is to do just as described above, pull the cluster, clean the terminals and connectors, slightly pry them up a bit so they make good contact when you re-insert the cluster.
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Amsoil Dealer
