will 4 in lift make me un stable
Destefano027
PostPosted: Fri Nov 18, 2005 2:48 pm    Post subject: will 4 in lift make me un stable Reply with quote
will a 4 in lift make my jeep unstable and roll over alot easier and where is the cheepest place to get it from will it be better to go with stock springs or a lift
PostPosted: Fri Nov 18, 2005 3:22 pm    Post subject: Reply with quote
Depends - it'll change the handling characteristics from stock, no doubt. But the rate of the springs, shock valving, tire height and width will also play into it. What model are you asking about?
