Oil seal
GREATONES96
PostPosted: Mon Oct 24, 2005 11:08 am    Post subject: Oil seal Reply with quote
I noticed i had a few drips of oil under the jeep the other day and i hate oil leaks. The leak is inbetween the tranny and the back of the engine,Is there just a seal, so if i drop the pan i can replace it and ill be done?Or is this more work than im thinking? Did i mention i HATE leaks. pissed
GREATONES96
PostPosted: Fri Oct 28, 2005 7:16 am    Post subject: Reply with quote
Im desperate, Has anyone ever replaced the pan gasket and seals? 1997 4.0
Hognuts
PostPosted: Fri Oct 28, 2005 7:21 am    Post subject: Reply with quote
I have a 98 XJ limited, and Mrs. Hognuts has a 00 XJ limited. We get a little oil there on both of em usually after an oil change. the guys at the valvoline store spill it out of the filter when they change it and it runs back there. I hope that is all it is for you too.
I wonder what this button does...
GREATONES96
PostPosted: Fri Oct 28, 2005 7:32 am    Post subject: Reply with quote
No i checked its coming from the seal. Thank you though.
03TJX
PostPosted: Fri Oct 28, 2005 10:15 am    Post subject: Reply with quote
Most likely the rear main seal leaking. The 4.0 is notorious for it. From what I understand, hope you have plenty of time and patience if you are doing the work yourself. Haven't had to do one, but I heard they are a PITA.
JEEP= Just Empty Every Pocket
If opportunity doens't knock, build a door
2003 TJ "X", 4.5" RE SuperFlex Lift
Tom Woods Drive Shaft, Advance Adapters SYE, 33x12.50x15 Interco TrXus MT on 15x10 Aluminum Wheels, Jeeperman Rear Bumper&Tire Carrier
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
GREATONES96
PostPosted: Fri Oct 28, 2005 11:20 am    Post subject: Reply with quote
It looks aas if all you have to do is drop the pan and place a new seal on but im not sure.
