Author |
Message |
jppilot61 Moderator
Posted: Fri Oct 28, 2005 2:10 pm Post subject: No Longer a pitiful STOCKER! |
I am ELATED with it and I'm really looking forward to wheelin it! Course I still need my Rear Drive Shaft.
RE6130 4.5" XJ Super-Flex Kit
RE1801 Slip Yoke Eliminator Kit NP231 Pre-1996
RE1898 Driveshaft CVF RE1801/7 (On Order)
Goodyear MTR 32 x 11.50R15 Tires
Cragar Series 352 Black Simulated Bead lock Steel Wheels
I will still likely need to do some trimming but . . . That's another story!
THANKS for EVERYTHING Phantum !!!  |
Back to top |
Jen2Goofy Trail Goddess
Posted: Fri Oct 28, 2005 2:27 pm Post subject: |
very nice!! btw, I like the tires and rims
Mark is a copy cat, I had them first!
MJ, can you get in it or will Mark need to get you a stoll? _________________ Some people are like slinkeys, they’re not of much use but they will still bring a smile to your face if someone pushes them down the stairs.
www.vajeepgirls.com
www.fm2cd.com
(O||||||O) |
Back to top |
StreetDoc Member
Posted: Fri Oct 28, 2005 2:47 pm Post subject: |
How are you susposed to hit rocks with that?
Oh no, I see it now - Black 2s  _________________ DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life." |
Back to top |
majikxms Moderator
Posted: Sat Oct 29, 2005 1:19 am Post subject: |
Jen2Goofy wrote: | very nice!! btw, I like the tires and rims
MJ, can you get in it or will Mark need to get you a stoll? |
Looks better on an XJ!!!  |
Back to top |
jppilot61 Moderator
Posted: Sat Oct 29, 2005 4:49 am Post subject: |
Mary Jane ABSOLUTELY needs a Stool! She has to perform an AWKWARD manueuver to try to crawl up into seat as it is now!
We will either need to load her in ONCE before we leave home and she'll have to take care of everything else in the vehicle (Could be unpleasent!) OR we'll need to install Rock Rails/Running Boards with a step incorporated! (ALL part of my master plan!) |
Back to top |
Billy's89XJ Member
Joined: 03 Jul 2004 Location: I'm the Charlie Browniest
Posted: Mon Nov 07, 2005 3:07 pm Post subject: |
Looks good Great job!!!! _________________ "GODZILLA" More than a Jeep, it's family!! |
Back to top |
jppilot61 Moderator
Posted: Wed Nov 09, 2005 3:20 pm Post subject: |
Finally got my Rear Drive Shaft! (Monday)
Immediately decided to TRY to get it mounted. Almost immediately realized that in the confusion of the difficult SYE Installation, the Dead Battery and several trips back and forth to Phantom's house, I lost the 4 Bolts and Lock Nuts to mount Drive Shaft. I called RE to get spec's on Grade 8 bolts and nuts and was informed that IF we had already mounted the SYE Flange WITHOUT the bolts installed from BACKSIDE that we had already messed up! I argued that Instructions didn't say a word about that and I was informed that I must have an OLD set of instructions. (I went and checked mine and the websitre to make sure this was not mentioned and it was not!
I was smuggly notified by RE that they recomemend PROFESSIONAL installation! I was a wee bit peeved! I plan to write them a LONG DETAILED letter after I calm down a bit!
So I went out got replacement hardware and began my 2 day ordeal to get Stainless Steel Flange off (It was almost impossible to get back on again LAST WEEK when I discovered the Oil Seal wasn't seated correctly - ANOTHER step that wasn't adequately covered in Installation Instructions!!! Was eventually lucky enough after two days of pounding on it to get it to slip partially off so I could mount bolts from back (with Thread Lock as recommended by RE). Then POUNDED it back in place and bolted it firmly to Transfer Case output shaft and FINALLY mounted and Greased my Driveshaft!
I am now mobile!
ANOTHER HARD LESSON LEARNED!
I am MOST anxious to go wheeling after MJ and I get back from Scotland! |
Back to top |
majikxms Moderator
Posted: Fri Nov 11, 2005 1:29 am Post subject: |
As many lifts and mods Steve has done I would think he qualifes as a professional....professional what is the question, but professional none the less  |
Back to top |
jppilot61 Moderator
Posted: Fri Nov 11, 2005 3:47 am Post subject: |
That is the way I felt too!
I would NOT have wanted to try that installation without his help!
They really "Frosted my Flakes" with that comment and their attitude about their instructions and my delima! I am pleased with the outcome and their product but am dissapointed with their lack of customer service.
They seemed to assume certain steps would be taken even though they completely left those steps out of Their INSTALLATION INSTRUCTIONS! They even seemed aware of the fact that they weren't in there but have made NO move to correct them? Its ONLY a piece of paper, how long does it take to clarify and reprint them for the next poor sap!
I had chosen to order DIRECTLY from Rubicon Express versus a authorized distributor in case I needed their assistance in exactly such a circumstance! I am still gullible enough to hope that my experiences with them on the phone were just coincidence of catching a couple of different people on OFF days and NOT representative of their true company mode of customer service! |
Back to top |
quadna71 Member
Posted: Fri Nov 11, 2005 6:16 am Post subject: |
jppilot61 wrote: | ...I am still gullible enough to hope that my experiences with them on the phone were just coincidence of catching a couple of different people on OFF days and NOT representative of their true company mode of customer service! |
hate to break it to you but you didn't catch them on an off day. RE's customer service flatly sucks - but the quality of their parts generally makes up for it. speaking from experience...not heresy.
chris
p.s. awesome looking XJ!!!! _________________ 2003 TJ Sport |
Back to top |
jppilot61 Moderator
Posted: Sat Feb 04, 2006 4:59 pm Post subject: Trimmed some today! |
Before:
After:
Will likely remove the fenders from rear, trim what I can then install DPG Rear adjustable bump stop plates.
Still need to replace exhaust (old, leaks and pretty banged up from last Paragon trip!
I also have a replacement Gas tank (also dented severely from Paragon last year) that I'd like to install before March! Only have about 3/4 of capacity it should but doesn't leak.
What Think? |
Back to top |
ThePhantum Pissed-Off Admin
Posted: Sat Feb 04, 2006 9:53 pm Post subject: |
Nice job.  _________________
Quote: | Never argue with idiots, they drag you down to their level and beat you with experience |
Back to top |
majikxms Moderator
Posted: Sat Feb 04, 2006 11:30 pm Post subject: |
That's a straight ass cut, great job!!! |
Back to top |
jppilot61 Moderator
Posted: Sun Feb 05, 2006 10:45 am Post subject: I just replaced my saggy old headline |
I just replaced my saggy old headliner with the kit I ordered from
www.wlsheadliners.com
I found it very easy and hardest part was removing all trim to release the headliner backer board.
I could probably do a better job it Idid it over again but it is definitely an improvement over the old one which drooped all over the place.
What's everyone else doing as far as upgrades getting ready for Wheelin Weather. (Guess I could have started new thread but . . . . )
Back to top |
rovertmutt Member
Posted: Mon Feb 06, 2006 8:21 am Post subject: Mods? |
Not much. I'm getting ready to order a lock rite for my rear. I might get a skid or two and another tow hook up front, but that might be it for a bit.
Yank can't wait for the next trip. He keeps going to the jeep every time I let him out front.
-Trevor.
[edit] provided that Steve could lend me a hand, garage, and tools. [/edit] _________________ Grrr! |
Back to top |
