Gearing down 93 XJ...4:56's or 4:88's?
JtotheEEPxj
PostPosted: Tue Nov 01, 2005 8:20 pm    Post subject: Gearing down 93 XJ...4:56's or 4:88's? Reply with quote
I just picked up a 93 XJ with a 4.5" lift and 32's already on it. It still has the stock D30 and D35 axles. I'm pretty new to these trucks, and dont know much about jeep drivetrain yet.....
I'm going to be hitting the Rubicon Trail and other related trails a couple times a year, other than that, it's my daily driver. I'm trying to decide on a good ratio that's low enough for rock crawling, and am still able to cruise about 60-65 or better on the freeway. Are 4:56's or 4:88's something i can use with the manual tranny? If not, what is?
I've heard bad things about the D35 rear axles being too weak, but I've also had Jeep guys tell me that they hold up alright if you're easy on em, and dont put a true locker in em. Mine's a posi right now and doesnt seem to have a problem in the small rock sections ive already done. What are some of your opinions on the 35 axle??
Ive heard good things about the D30 frt axle...as long as you dont lock em up....and do the manual hub conversion, which is very expensive....
also, Will the D30 and D35 accept a larger 4:56 or 4:88 ring gear?? or do you have to replace the carrier? if you do, where can i get them and what other vehicles can I get them out of?
I'd really appreciate any info , thanks
"If it ain't dented, ya ain't wheelin' hard enough"
-1993 XJ, 4.0, 5 spd, 4.5" lift, 32's, Warn bumper, JKS link kit, skid plates, D30 & 8.25 w/ 4:56's & Detroit locker
-1965 Ranchero, new paint & interior, 302, C4, torque thrust II whls
PostPosted: Tue Nov 01, 2005 9:57 pm    Post subject: Re: Gearing down 93 XJ...4:56's or 4:88's? Reply with quote
There's a discussion going on right now on axle options. http://www.jeephorizons.com/phpbb/viewtopic.php?t=6159
If you do a search you'll find more threads like that one.
My opinion? The D35 is a turd...but if you are easy on them they will hold up. I would not put a lot of money into one though. Again, that's my opinion.
4.56's will be just fine for 32's...might even be a bit of overkill on the road...but it will definatley crawl. As far as the carriers you will have to replace them (the cutoff point is 3.55's). Anyplace that sells the gears should also sell the carriers.
JtotheEEPxj
PostPosted: Wed Nov 02, 2005 9:39 pm    Post subject: Reply with quote
thanks for the info.....i really want to invest in a d44 rather than a d35, but the local wreckers want 900 to 1000 bucks for a 44. so i'd be real lucky to come across one out of a parts truck for anywhere near 500 bucks. I might just end up investing in my 35 and being real easy on it. appreciate all the help, thanks again
PostPosted: Wed Nov 02, 2005 9:48 pm    Post subject: Reply with quote
That's insane. Check around on naxja.org and jeeps unlimited. They usually go for between $3-400 I found mine on JU for $300. I just had to drive 100 miles up to Maryland to pick it up.
