Detroit TrueTrac Differential #912A310. Dana 35, 3.54
WannaBJeepin
PostPosted: Sun Nov 06, 2005 6:49 am    Post subject: Detroit TrueTrac Differential #912A310. Dana 35, 3.54 Reply with quote
I have a stock TJ 4cyl. I am thinking about getting a TrueTrac for it. From what I can tell, this model will fit my Jeep. Can anyone verify that for me?
Tim Martin
98 Sport
35" MTR's
5.5 Rubicon Extended arm Lift
Winch
Centerforce Dual-Friction Clutch & Pressure Plate
Custom Front & Rear Bumper's & Tire Carrier
Braided Break Lines
Warn Manual Locking Hubs
ARB's
Air System Purchased and in the works
PostPosted: Sun Nov 06, 2005 12:55 pm    Post subject: Reply with quote
It appears Tractech only makes the TrueTrac for the 3.54 and higher gears in a D35. It is part number Tractech part no. 912A310.
http://www.tractech.com/docs/TT-List-LTPM1004.pdf
So yes, it looks like you've got the right part.
Now, you do realize this isn't something the average shadetree mechanic can install. The TruTrac is a full case design and will require a complete gear setup to install it. If you'll be using a shop, you may have to get the parts through them. A lot of shops will only work with parts purchased through them.
WannaBJeepin
PostPosted: Mon Nov 07, 2005 5:26 am    Post subject: Reply with quote
Oh man that sucks. After I sent my post, I did find someone that knew that this was the correct part, so I bought the item from an individual who got it new and never installed it. So now I have it and am stuck with it. Do you know of any instructions online of how to install it, extra parts required, and tools required so I can see what I got myself into?
Thanks from a formerly excited now concerned Jeeper,
Tim
98 Sport
35" MTR's
Winch
Braided Break Lines
ARB's
PostPosted: Mon Nov 07, 2005 7:50 pm    Post subject: Reply with quote
Doing an R&P setup requires a few special tools as well as a bit of expertise. Unless you have a very clear idea of what you are getting into and what's involved, do not attempt it. In laymans terms, if the gears are not setup to "mesh together" just right, they will eat themselves within a few hundred miles.
Here's a few writeups that will give you an idea of what's involved:
http://www.off-road.com/toyota/gears.html
http://www.drivetrain.com/ringpinioninstal.html
http://www.hotrod.com/techarticles/84118/
