2005 SEMA Show Photos
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Jeep News
PostPosted: Tue Nov 08, 2005 11:44 am    Post subject: 2005 SEMA Show Photos Reply with quote
A couple of Jeep's entries at SEMA:
Off-Road Commander Concept. Partnered with Superlift Suspensions, American Expedition Vehicles and supported with donations from Mopar and ARB 4x4. The base vehicle is 2006 Commander Limited with 5.7 L HEMI and Quadratrac II 4wd.
Prototype 4.5-inches suspension lift allows the Off Road Commander to be fitted with massive 35-12.50 x 17 BF Goodrich Mud Terrain tires. The tires are covered with custom fabricated wheel flares and a heavy guage steel rock rail. Mopar accessories: front brush guard, roof mounted aluminum cargo basket, prototype tail lamp guards.
Street Commander Concept “sound chamber." The interior features a multi-media experience with DVD's, satellite, navigation, mp3, iPod, and Playstation interfaces.
grandjeeper
PostPosted: Tue Nov 08, 2005 6:31 pm    Post subject: Reply with quote
does anybody else think the street version looks like crap.
93 jeep grand cherokee 4.0 I6, 2inch spacer lift, 31 BFG AT,
grandjeeper
PostPosted: Tue Nov 08, 2005 6:32 pm    Post subject: Reply with quote
now that off-road concept looks pretty freakin sweet
PostPosted: Wed Nov 09, 2005 4:40 am    Post subject: Reply with quote
Here are the rest of the photos:
Jeep XJ Dual Battery Tray Kit
New XJ auxiliary battery tray kit. Complete kit consists of custom cable kit, 200A isolation relay, and battery manager that mounts in the cab.
Wrangler Northwest Power Product
http://www.wranglernw.com/
Replacement Steering Shaft
Replacement intermediate steering shaft for 1997-1006 Jeep Wrangler. Replaces stock upper or lower shaft between steering box and steering column.
Borgeson Universal Co., Inc
http://www.borgeson.com/
1987-95 Jeep YJ 8 Crawler Coilover System
Converts front suspension from leaf spring to a bolt on radius arm coilover while rear suspension receives soft ride leaf spring over conversion with a traction bar. Subsantial gain in suspension articulation and travel.
Fabtech Motorsports
2005 Jeep ZJ Grand Cherokee 3 Coilover System
System replaces the OE strut assembly with an adjustable coilover shock for increased suspension dampening providing a smooth ride both on and off road.
Fabtech Motorsports
Rampage Universal D-Ring Recovery Shackle
Designed primarily for Jeep CJ and Wrangler mounts without drilling on Jeep applications, and can be used and mounted on other vehicles.
Rampage Products
www.rampageproducts.net
Cramp Killer Armrest
With thick pads, Rampages Cramp Killer Armrests provide riding comfort made for full and half door wranglers. Available in four OEM colors.
Rampage Products
Omix 7 Extended Fender Flare Kit for TJ
New 7 Extended Fender Flare Kit provides wider coverage for larger tires and wheels, while still maintaining a OE style appearance.
Omix-Ada, Inc.
www.omix-ada.com
NP231 Slip Yoke Eliminator Kit
Omix-Adas heavy duty SYE kit has the strongest housing available at the lowest price on the market.
Omix-Ada, Inc.
www.omix-ada.com
Rock Monster Wheels
Two-piece aluminum rims with engineered dual internal beadlock, for protection from tire bead unseating during off-road air-down conditions. D.O.T. compliant.
Hutchinson Industries, Inc
www.rockmonsterwheels.com
Jeep Wrangler Extreme Fan
Custom shrouded s-blade electric fan for 1987-2005 Jeep Wrangler four and six cylinder. Solid brackets mount to the OE radiator-mounting points, eliminating through-core bolts; maintaining a clean appearance. Replaces stock fan and shroud; provides cooler a/c, more horsepower, improved gas mileage, and extended water pump life.
Flex-a-lite Consolidated
Rubicon Full Float Kit
Full float axle kit to fit the Jeep Rubicon rear Dana 44 housing. Options include 30, 33, 35 spline axles.
Superior Axle & Gear
Radiator/Fuel Tank Skid Plate
Grand Cherokee radiator/fuel tank skid plate. Manufactured from aluminum. Protects the radiator/fuel tank when driving off road.
Asfir Ltd.
www.asfir.com
Jeep TJ Bull Nose Front Bumper
Fully welded one-piece design is winch capable, standard 2 receiver, welded eyelets for shackle brackets. Bolts to existing holes for strength and installation ease.
Ranch Hand Truck Accessories
www.ranchhand.com
10x2 Subwoofer Box for Jeep Wrangler
Custom fit subwoofer box tailored to fit the exact shape of a Jeep Wrangler. Ported and tuned to offer unparallel base quality.
Smittybilt Automotive Group
www.gosmitty.com
Jeep LJ Front Lifestyle Bumper
Jeep LJ bumper that maintains high strength and trail functionality while simultaneously infusing additional style and design features.
Fab Fours, Inc.
www.fabfours.com
Jeep LJ rear bumper with Tire Carrier
Robust rear bumper with swing out tire carrier and high lift mount for Jeep LJs. This bumper has style and design features that have never been seen in the market.
Fab Fours, Inc.
www.fabfours.com
Air-Zenith 200PSI Fast Air Pump
200PSI Rated, 100% duty cycle, moisture and dust resistant, engineered for air ride vehicles. Patented interchangeable piston technology allows self-repair piston ring to extend air pump life.
Zenith USA, Inc.
WWW.AIR-ZENITH.COM
12-Voltair Compressor
Air where and when you need it. 12-Volt air supply, 1 hp, 150 psi air compressor for air tools, tires and any air need. 75% duty rated.
12-voltair
www.12-voltair.com
ECTED Locking Differential for Dana model 30 and 35 Axles
Revolutionary with respect to traction technology. ECTED allows the user to select between limited slip or a locked differential.
Auburn Gear Inc.
www.AuburnGear.com
WARN 9.0Rc Winch
A short-drum, 9,000-lb. capacity winch with a 4.8 hp Series Wound Motor built for rock crawlers looking for efficiency and legendary WARN performance.
Warn Industries
www.warn.com
Electric Jeep Top
The world's first electric convertible top for the Jeep Wrangler and Unlimited. Top goes from closed to open in nine seconds flat.
Barker Gang Garage, Inc
www.barkerganggarage.com
Bushranger X-Jack
Lifting capacity of over 8,800 lbs.; an exhaust jack is ideal for use in sand, mud and snow. Inflated by a hose that connects to your tailpipe. The first air jack with two-way inflation, that uses either the exhaust or a portable air compressor; up to 30" of lift.
ARB
www.arbusa.com
Compact Compressor
A low volume, low-amp drawing compressor designed to operate ARB Air Locking Differentials and other low volume vehicle components.
ARB
www.arbusa.com
Tube Doors for Jeeps
Come with hinges and either a paddle handle, deluxe version, (displayed) or our standard version. Latch pin only. Powder coated black for a long lasting, durable finish. A superior door for all YJ and TJ Jeeps.
Warrior Inc.
www.warriorproducts.com
Tom Woods Super-Duty 231 Tail Shaft Conversion
231 Transfer case conversion. Stronger than a yoke, the universal flange design will allow the use of drive shafts in the widest variety.
Tom Woods Custom Drive Shafts Inc.
WWW.4XSHAFT.COM
XACTBalance
The first and only weight thats truly dynamic. As you drive, XB adjusts to provide a precise balance and a smooth ride.
International Marketing, Inc.
www.imiproducts.com
ShokArmor
ShokArmor Systems help protect rear shocks from damage due to stone blast, impacts and abrasions from large obstacles. Easy bolt on installation.
Specialty Products Co.
www.specproc.com
Energy Suspension Transmission Mount for 1997-1005 Jeep Wrangler
Energy Suspension HYPER-FLEX performance polyurethane transmission mount for the 1997-2005 Jeep Wrangler provides greater strength, durabilty and longevity over rubber mounts.
Energy Suspension
www.energysuspension.com
MP-8
This universal diesel performance module has all major diesel brand applications in one unit. Communicates directly with the engines ECM, and receives vital engine and fuel system information. Available for Ford, Dodge, Chevy, International and Jeep Liberty CRD.
TS Performance
www.tsperformance.com
Garmin GPSMAP 376C
Garmin GPSMAP 376C is a new and highly versatile Garmin-built GPS navigation system designed specifically for the Jeep Wrangler.
Garmin International
www.garmin.com
Jeep Trail Guide
The ultimate in portability and versatility, with XM radio and satellite weather capability along with marine and land navigation modes.
www.garmin.com
PostPosted: Thu Nov 10, 2005 2:30 am    Post subject: Reply with quote
And some more excellent photos. Wink
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Jeep News All times are GMT - 8 Hours
