2001TJ wiring diagram (but could help other models/years)
Black2001TJ
Leopard Skin
Leopard Skin
PostPosted: Fri Jan 30, 2004 11:26 am    Post subject: 2001TJ wiring diagram (but could help other models/years) Reply with quote
I just remembered I have this... Enjoy!
Constant Power : PNK/BLU OR RED IGNITION SWITCH HARNESS
Ignition Power : BLU IGNITION SWITCH HARNESS
Starter Kill : YEL IGNITION SWITCH HARNESS
Door Trigger : YEL (-) 14 PIN GRY CONN DRIVERS KICK PANEL
Parking Lamp : BLK/YEL (+) AT LIGHT SWITCH
Remote Start Wiring Location
Starter Wire : YEL IGNITION SWITCH HARNESS
Tach Sensor : GRY/WHT (-) OR GRY (-) AT COIL
Ignition (1) : BLU IGNITION SWITCH HARNESS
Ignition (2) : BLK/ORG IGNITION SWITCH HARNESS (HEAT/A.C.)
Accessory : BLK/WHT IGNITION SWITCH HARNESS
Brake Switch : WHT/TAN (+) AT BRAKE SWITCH
Speed Sensor : WHT/ORG 8000 WIRE HARNESS FROM TRANSMISSION
Reverse Lamp : VIO (+) DRIVER'S KICK
Accessories Wiring Location
Window Up : N/A
Window Down : N/A
Trunk Release : N/A
Horn (Relay) : BLK/RED (-) AT STEERING COLUMN
Head Lamp : LT.GRN (+) AT LIGHT SWITCH
Wiper : GRY AT WIPER SWITCH
Radio Specifications
Type : DIN
Depth : 7"
Kit : YES
Antenna Information
Type : MAST
Radio Notes *
Memory : PNK/WHT
Ignition Pwr : PNK
Ground : CHASSIS
Illumination : ORG
Dimmer : BLK/YEL
Front Speakers *
Size : 4 X 6"
Kit : FACTORY GRILL
RF(+) : BLU
RF(-) : VIO
LF(+) : BRN/RED
LF(-) : GRN
Rear Speakers *
Kit : FACTORY KIT
RR(+) : BLU/WHT
RR(-) : BLU/RED
LR(+) : BRN/YEL
LR(-) : BRN/BLU
