Small coolant leak
rodneyjt24
PostPosted: Sun Nov 20, 2005 11:36 am    Post subject: Small coolant leak Reply with quote
88 Cherokee with a straight 6. I have a small coolant leak that appears to commimg from the pass side or center of engine. All the hoses are good, no leaks from them. Just cant seem to find where this is from. Heater core is good. Could it be from any plugs on the rear of the engine? Which ones?
PostPosted: Tue Nov 22, 2005 5:48 pm    Post subject: Reply with quote
There should be plugs on the side of the engine block. That could be the cause of the leaking.
rodneyjt24
PostPosted: Tue Nov 22, 2005 7:05 pm    Post subject: Reply with quote
I looked at the ones on the side, they appear to be ok. There are two behind the flywheel, one on the back of the head. Guess I will have to try and check them too.
87xj
PostPosted: Sun Nov 27, 2005 2:04 pm    Post subject: Reply with quote
It could be the resevoir bottle itself. I had the same problem on my 87, the nipple 1/2 way up the bottle on the right has a tendancy to crack. If this is the problem just order a new one off of ebay (i used 1aauto or something like that, they are located maybe 20 minutes from me). Make sure it has the steel reinforced nipples or you might end up doing it again.
87 Cherokee
3.5 RE Superflex
32" Super Swamper TSL's waiting on rims...
