Leaking Differentials
rudeboyrob88
PostPosted: Mon Nov 28, 2005 2:34 pm    Post subject: Leaking Differentials Reply with quote
Hey, I was wondering if there is any reason that my Diffs would be leaking. I have not done as much off roading as I would like to have done by now, and my rear and front diffs are both leaking. The rear is worse. Is this normal wear and tear, or could it be something else? Ie: put a 4" lift on, Put on 31's without re-gearing it. Drove it that way in the Pismo dunes? would any of these be reasons for the Diffs to leak?
'01 Cherokee Sport, 4" lift, Centerforce II Clutch, and more to come
JeepinNH
PostPosted: Mon Nov 28, 2005 4:22 pm    Post subject: leaks Reply with quote
Where are they leaking from? Seems to be somewhat typical if you have the rubber fill plug type, they leak from there because of the rust/grime buildup.
