Metric Versus Standard Tire Sizes
nixt
PostPosted: Wed Nov 30, 2005 7:54 pm    Post subject: Metric Versus Standard Tire Sizes Reply with quote
I can never remember the formula to convert the metric tire sizes to the English system floatation grade sizes. I am going to list below a few web sites that have calculators that do it for you- all you have to do is plug in the numbers. However, these numbers are not entirely accurate because each maker measures their tires differently. I would advise you to double check with the manufacturers website if your measurements need to be extremely precise. Here are the web sites:
http://www.powerdog.com/tiresize.cgi
http://www.csgnetwork.com/tireinfo4calc.html
http://www.dakota-truck.net/TIRECALC/tirecalc.html
http://www.4lo.com/calc/gearmetric.htm
Nixt
JKS disconnects & Garmin GPS
Heavy duty OME Suspension kit
Life has No Value,
But Death Has Its Price.
