Author |
Message |
1fox2go Member
Posted: Wed Dec 07, 2005 7:34 pm Post subject: |
Just upgrade the rear to disc brakes...ive heard that its much more rare for the discs to grab like the drums do _________________ 96 Cherokee 7.5 inch TnT long arm Locked F/R, D44 rear, 4.56s, 35x12.50 Muds/36x12.50 TSLs
Back to top |
DozerDan What the deuce?
Posted: Wed Dec 07, 2005 8:43 pm Post subject: |
1fox2go wrote: | Just upgrade the rear to disc brakes...ive heard that its much more rare for the discs to grab like the drums do |
No just learn to drive, drum brakes have been around literally FOREVER, hell cars used to use them in the front too
Disk brakes are great in the rear, but I highly doubt they would have helped much here. _________________ Fabricator for hire.... contact me for info |
Back to top |
grandjeeper Member
Posted: Thu Dec 08, 2005 4:52 am Post subject: |
the computer dianostic ran an era with the abs, i for get the code, but basically the abs doesnt work right. i am actually better off with out abs for know, utill it warms up and i can fix it. _________________ 93 jeep grand cherokee 4.0 I6, 2inch spacer lift, 31 BFG AT, |
Back to top |
Stevo02TJ Member
Joined: 02 Jan 2005 Location: Waynesboro and Harrisonburg, Virginia
Posted: Thu Dec 08, 2005 10:23 am Post subject: |
DozerDan wrote: | drum brakes have been around literally FOREVER, hell cars used to use them in the front too  |
My mustang has drums in the rear AND front, and it stops before I hit anything (Well, minus one time, but I admit it was my fault, and not the brakes! ) |
Back to top |
Stevo02TJ Member
Posted: Thu Dec 08, 2005 10:24 am Post subject: |
I've heard they are worse.  |
Back to top |
viper24242 Member
Posted: Thu Dec 08, 2005 10:44 am Post subject: |
I know that car disc brakes have a lot of electronics and what not crontroling them in these modern times, but to take a simplified look at disk brake they are stonger than drum brakes. So with increased stopping power comes the ability to lock them up when hard fast pressure is put on them.
I have never had the drums on my Jeep lock up. In fact I wish I had disks on all 4 wheels. The only time I have ever locked them up was during panic stops and then it was only for a split second untill the abs took over and started to "pump" the brakes.
In my opinion I would just start stopping earlier and modulate the brakes a little easier. _________________ '94 Grand 5.2L
Rusty's Tie Rod Conversion |
Back to top |
Posted: Thu Dec 08, 2005 3:00 pm Post subject: |
Yup pretyt much general conclusion would be that you need to drive better, and not blame the car for making you get in an accident.
And get you abs fixed, or stop driving the car, obviously there is something wrong with it- so fix it.
Stearing and Brakes are two things you DO NOT MESS AROUND WITH WHEN IT COMES TO A VEHICLE!!! _________________ Fabricator for hire.... contact me for info |
Back to top |
viper24242 Member
Posted: Thu Dec 08, 2005 6:11 pm Post subject: |
The one thing that unites all human beings, regardless of age, gender, religion, economic status or ethnic background, is that, deep down inside, we ALL believe that we are above-average drivers.
--Dave Barry _________________ '94 Grand 5.2L
Back to top |
1fox2go Member
Posted: Thu Dec 08, 2005 7:28 pm Post subject: |
He wasnt talkin about them locking up under full break he was saying something along the lines that they grab even after light pressure my jeep does it but after u hit the brakes a few times it goes away and all is fine i do believe that is what grandjeeper was talking about unless i missed something....thats why i said discs wont do that as often or as bad _________________ 96 Cherokee 7.5 inch TnT long arm Locked F/R, D44 rear, 4.56s, 35x12.50 Muds/36x12.50 TSLs
Back to top |
grandjeeper Member
Posted: Sun Dec 11, 2005 11:27 am Post subject: |
1fox2go, thank you. someone finally is getting what im saying. its not me, the jeep will sometimes just lock the rear up. if hit the brakes a couple times, it goes away. it just so happened that my jeep was having this accurance when someone stoped in front of me. i admit, i knew that my jeep sometimes will do this and i could have not drivin it that day, but as far as me hitting him, wasnt my fault.
by the way. i talk to my friend you has 2 tj's, 3cj's, 1yj's, and 2 zj's; he said that both of his zj will do this same thing, but none of the other cars with drums do it like the zj does. so i think like 1fox2go was sayin, it only zj's for some reason. well, this is my conclusion. _________________ 93 jeep grand cherokee 4.0 I6, 2inch spacer lift, 31 BFG AT, |
Back to top |
1fox2go Member
Posted: Sun Dec 11, 2005 11:47 am Post subject: |
yea just take it easy in the mornings after it rains or snows and while going down the road I ease my foot on the brake pedal that way they dont grab every time you come to a stop
know what i mean?
and OH by the way before anyone says its bad brakes i have NEW drums AND shoes in the rear...still does it _________________ 96 Cherokee 7.5 inch TnT long arm Locked F/R, D44 rear, 4.56s, 35x12.50 Muds/36x12.50 TSLs
Back to top |
grandjeeper Member
Posted: Thu Dec 15, 2005 5:22 pm Post subject: |
yeah i engine brake alot, try to brake only with i have to. _________________ 93 jeep grand cherokee 4.0 I6, 2inch spacer lift, 31 BFG AT, |
Back to top |
1fox2go Member
Posted: Thu Dec 15, 2005 5:46 pm Post subject: |
yea i do the same _________________ 96 Cherokee 7.5 inch TnT long arm Locked F/R, D44 rear, 4.56s, 35x12.50 Muds/36x12.50 TSLs
Back to top |
