Wont go into overdrive
Jeep Iceland
PostPosted: Thu Dec 15, 2005 3:49 pm    Post subject: Reply with quote
Just finished tearing the trans down, #1 forward clutch was the problem,if I just would have removed the trans right away instead of replacing the solenoids and yadayadayada I'd be $2000 richer.
Metal all over,well good part is the tranny will be completely rebuilt with a rebuild kit and the converter will be refreshed and upgraded too.
Also the junk metal destroyed my #1 sun gear.
Thanks to all who tried to help. Smile
F.D
1996 Limited 5.2
http://www.cardomain.com/id/461ponchos96jeep
1976 Trans Am
http://www.cardomain.com/memberpage/531601
PostPosted: Thu Dec 15, 2005 5:41 pm    Post subject: Reply with quote
yea im going to rebuild mine and try to beef it up...Iceland you have the v8 right? i found shift kits at summit racing while im in there im going to do all i can to beef it up
Jeep Iceland
PostPosted: Thu Dec 15, 2005 7:04 pm    Post subject: Reply with quote
Yup I have the shift kit already installed,had that done along with the solenoids at first,now ist just the "super rebuild kit" and a new sun gear.
Should be better than new Cool
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Fri Dec 16, 2005 10:46 pm    Post subject: Reply with quote
super rebuild kit? what else besides the shift kit are you doin to make your trans stronger?
Jeep Iceland
PostPosted: Sat Dec 17, 2005 1:23 pm    Post subject: Reply with quote
sorry,it's not called super it's called deluxe,just includes more parts then the other one.
Well the shift kit that I had installed is supposed to make it more reliable and the converter will be upgraded as well,I have no idea what they do for it though.
F.D
1996 Limited 5.2
1976 Trans Am
Jeep Iceland
PostPosted: Thu Dec 22, 2005 1:03 am    Post subject: Reply with quote
Just got my converter back,it was the cause of the whole thing,somthing broke inside (band) and got into the cooler (radiator) so I have to by-pass the radiator and use a new trans cooler.
Hope to have it all together before this weekend.
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Thu Dec 22, 2005 2:59 pm    Post subject: Reply with quote
so your converter went bad and the inside of the trans was fine?
Jeep Iceland
PostPosted: Fri Dec 23, 2005 10:43 am    Post subject: Reply with quote
Nonononono the converter (lock up band) vent bad and pieces of it went thru the trans to the radiator, clogged it or possibly the pressure dropped and then the forward cluch overheated and metal from it went everywhere.
Now I bought a new Cooler just for the tranny and will bypass the radiator part.
Converter is rebuilt now and tranny is ready for install.
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Fri Dec 23, 2005 6:14 pm    Post subject: Reply with quote
ohhhh got ya so you had metal in your pan as well?
Jeep Iceland
PostPosted: Sat Dec 24, 2005 9:45 am    Post subject: Reply with quote
At the very end yes,not at first.
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Fri Jan 06, 2006 7:09 pm    Post subject: Reply with quote
my lockup went bad as well but i caught it before the trans overheated...plus i installed a trans cooler
going to replace converter and possibly front pump mite as well replace the clutches and things that wear and tear
Jeep Iceland
PostPosted: Sat Jan 07, 2006 6:40 am    Post subject: Reply with quote
Good for you dude,I was told to get a good cooler replace the original one and by-pass the radiator.They said it's impossible to clean out the radiator part,I also installed a temp gauge for the trans fluid.
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Sat Jan 07, 2006 8:16 am    Post subject: Reply with quote
Same thing happened to mine.. I am doing a rebuild right now and am going to take off my Converter and drop it off at the shop on Monday..
I bought this
And am having custom braided steel lines made for Tranny cooling duty.. I am not going to rely on that stupid radiator any more....
I have taken lots of pics of the tranny rebuild and am going to do a writeup when I am done...
How far have you gotten along Iceland???
I am guessing you did the Transgo shift kit..
It was surprisingly easy... Are you haveing any difficulty with your tranny???
Overdrive unit on mine seems fine.. I pulled it off and used the feeler gauge and everything is up to specs.. (But I did start with a tranny from another ZJ not my own...)
Are you going to get a new Radiator or do something else for cooling issues???
Jeep Iceland
PostPosted: Sat Jan 07, 2006 2:47 pm    Post subject: Reply with quote
I did nothing my self but too help my budddy ,who rebuilt the trans,to install it after rebuild,to busy these days.
Mine is up and running like new Smile
The radiator part is not so stupid it warms up the fluid more quickly when it's cold,but I by passed it like the pro's who rebuilt the converter told me to do.
The shift kit was called A500 on the receipt.
F.D
1996 Limited 5.2
1976 Trans Am
b_walls171
PostPosted: Fri Jan 13, 2006 5:52 pm    Post subject: Same problem (i think) Reply with quote
I think I have the same prob. I was driving down the highway one day and my tranny jumped out of overdrive into third gear. Drives fine until I get to fourth gear. I have a 98 JGC. I have already replaced the tranny once. Please re-post and let me know what you ended up having to do. or if any one else has any suggestions it would be appreciated.
Trying to trust jeep and chrysler again
