New tires
allard002
PostPosted: Wed Dec 07, 2005 9:01 pm    Post subject: New tires Reply with quote
Hi, a few months ago I bought some 20 inch rims for my 2000 Jeep Grand Cherokee that came with 27/45/20 tires. I was wondering if anyone knew if 255/35/20 tires would fit because I want to get lower profile tires.
Thanks
nixt
PostPosted: Wed Dec 07, 2005 10:07 pm    Post subject: tire sizes Reply with quote
20 inch rims aren't really my taste- I've got 16's now and I wish I had 15's because I would have a wider variety of tire designs and sizes (and they would be cheaper). First you need to know what size rim and tire came on the jeep from the factory. Did it come with 20's from the factory, were they a dealer installed option, or did you just go out and buy them? If you don't already know here is what the tire size means:
using the 245/75R16 as an example
the first number 245 is the width of the tire in millimeters
the second number 75 is the aspect ratio meaning the profile of the tire is 75% of the width (245) which equals 183.75
the third number is the rim size 16
to get the overall diameter you would add 183.75 to 183.75 which equals 367.5 millimeters which you would then convert to inches and add to the rim size. I can never remember these conversions so I made a post a while back called Metric Versus Standard Tire Sizes in which I put some links to websites that have programs you can use to figure all this out by just plugging in the tire size- so be sure to look up that post.
Back to your question- if it came with 275/45R20 then the original profile would be 123.75 millimeters. You want to put on 255/35R20 tires which have a profile of 89.25 WHICH WOULD RESULT IN A SMALLER OVERALL DIAMETER WHICH MEANS THEY WOULD FIT. I'm not sure of the actual diameters of either of the tires because each tire manufacturer measures differently even if the numbers on the tires are the same. Most manufacturers list the actual overall diameter of their tire sizes on their website so check that out too. You didn't mention the rim width or backspacing but be careful if you get new rims in the future because they may not clear the brakes or suspension components. Also, THIS PART IS IMPORTANT: when you change the tire/rim size and the overall diameter is different from what came from the factory by 15%, (5% on cars) you must update the vehicle's software because your antilock brakes will not operate properly, the speedometer will not be accurate, and neither will the odometer. Not to mention the bone-jarring ride that low profile tires on trucks and suvs cause. Larger rims result in greater unsuspended (unsprung) weight and therefore longer stopping distances. You can also call The Tire Rack or check their website for more information on changing sizes safely within the 15% window (they label it plus 1, plus 2, or minus 1, minus 2, etc...) but remember- any change will effect the speedo, abs, etc..., it is just that 15% has been judged to be an acceptable error because it is so minor.
I hope I answered your question, I know it was a long winded answer so I put the important stuff in all caps. But check out those websites and my other post because that is a hell of a lot easier than working out the math in your head.
Nixt
JKS disconnects & Garmin GPS
Heavy duty OME Suspension kit
Life has No Value,
But Death Has Its Price.
PostPosted: Thu Dec 08, 2005 1:12 am    Post subject: Reply with quote
Good info, nixt. Moving this to the tire section. Wink
