Gearing down an 8.25
JtotheEEPxj
PostPosted: Sun Dec 11, 2005 5:52 pm    Post subject: Gearing down an 8.25 Reply with quote
I've got a 93 cherokee xj, 4.5" lift, 5 spd, 4.0l, w/ 32's.
I finally found out that my rear axle is the Chrysler 8.25. I've already decided I want either 4:56 or 4:88 gears. Does it take an aftermarket carrier to install the gears? and is it true that you can only go as low as a 4:56 in an 8.25??
Also, how strong are the 8.25's?? I know the D44's and Ford 8.8's are a little more sturdy, but how weak is it really?? It's a daily driver that I plan on taking through Rubicon and other rock trails a few times a year.
Thanks for any input.
"If it ain't dented, ya ain't wheelin' hard enough"
-1993 XJ, 4.0, 5 spd, 4.5" lift, 32's, Warn bumper, JKS link kit, skid plates, D30 & 8.25 w/ 4:56's & Detroit locker
-1965 Ranchero, new paint & interior, 302, C4, torque thrust II whls
ILLXJ
PostPosted: Sun Dec 11, 2005 8:07 pm    Post subject: Reply with quote
For the 8.25 you do not need to change the carrier for 4.56's. That is as low as you can go. In a 93 you have the 27 spline version, not much if any stronger than the D35. I have the 29 spline, running 4.56's & 33's and haven't had any problems, yet. HTH. JIM.
________
ZX900A
scorpio_vette
PostPosted: Sun Dec 11, 2005 11:24 pm    Post subject: Reply with quote
plus if your not planning on going bigger than 33's, then i don't think you should even consider going above 4.10 or 4.56.
somebody correct me if i'm wrong.
________
Suzuki Fronte history
ILLXJ
PostPosted: Mon Dec 12, 2005 10:01 pm    Post subject: Reply with quote
I wish I had 4.88's. JIM.
________
Toyota V engine
