97 and up XJ heater not heating floor
iceman153
PostPosted: Wed Jan 23, 2008 10:31 am    Post subject: Reply with quote
That arm is exactly what was missing from my car Smile Have you ever tried removing that arm from the car??
I ask as i went to a wrecker this morning to grab that arm, as you said that yours just clicks into place, i figured it should just click out as well! Not the case, as i told the guy it should just pop out, we removed detached the servo from the arm, no matter how we wiggled it wouldn't come off easily, so he gave it a little force and the little "keyway" inside the arm snapped off, so i can see what shape it should be, i just need to frabricate something...
I think the reason yours keeps popping out is because it's actually broken, your just lucky that the entire "keyway" inside the arm didn't break off like the one did this morning. These arms aren't meant to come off, there is probably some plastic retainer on the end of the key to stop the arm from coming out. All you need to do is rig something up to press the arm tightly to the vent.
Would you mind removing your arm and taking a picture of the key that turns the vent? It would also let you see how it's damaged.
Thanks!
JeepinNH
PostPosted: Thu Jan 24, 2008 7:58 am    Post subject: Reply with quote
As I remember, the arm does come off because I think I remember looking at the clip inside. This was awhile ago so maybe I'm not remembering correctly. The last thing I did was put a piece of metal to hold it in but it has worked loose anyways. I'm not sure when I'll have a minute to get in there again but will see what I can do. How can yours be totally missing?
Mike
Present: 99 Cherokee
iceman153
PostPosted: Thu Jan 24, 2008 12:02 pm    Post subject: Reply with quote
I have no idea where mine went, it's been like this ever since i bought the car a year ago. I have a feeling whoever the previous owner got to install the alarm/CD deck accidentally broke it off and just chucked the peice. This is why I always do those types of installs myself Razz
Wow, if it actually does have a clip i should go back to the wrecker and work something out. Was there any special trick to getting it to come out? I'm very curious to see what yours looks like Smile
For now i actually found a Chop Stick that seems to be exactly the right size to fit into the key in the vent. I just have to file out a square in the vent arm for it to sit in, apply a little super glue, and i should be good. So painful, all of this because of a little peice of plastic. Hope this works, otherwise I'll have to find a way to rig the vent to have defrost permanently on. at least then i could see!
Mark
JeepinNH
PostPosted: Thu Jan 24, 2008 3:40 pm    Post subject: Reply with quote
Strange, the thing is far enough back you wouldn't think someone could break it but I guess you never know. Mine always clicks back in when I push on it and is as snug as can be, that's why I think there's a clip on there. I think the pull of the actuator puts enough torque on it that it slowly works it's way out. You can actually see it bend on mine. Maybe I'll try the video part of my camera for this.
Mike
JeepinNH
PostPosted: Sat Feb 02, 2008 8:50 am    Post subject: update Reply with quote
I took the radio out today to look at the vacuum arm. Everything is still clipped in tightly and moving as it should. I guess the piece of metal I screwed in there is holding the arm in well enough. Sorry iceman153, no extra pics to show because I didn't want to disturb the setup while it's working. I thought I was receiving less heat at the floor as of late but maybe that's just the was the XJ is.
Mike
