Is this Normal and more...
DIGITRUCK
PostPosted: Tue Dec 13, 2005 2:00 pm    Post subject: Is this Normal and more... Reply with quote
Hey,
88 XJ Cherokee Laredo 4.0L Auto. Just got done converting cooling system from closed to open. Now has CSF 3-Row All Metal Rad. Way Better than Stock.
With the engine idling and warmed-up, if I switch on to the MAX HEAT settings and blower on Full I notice the Volt Meter will drop from almost 14V to a little less than 12V. Only way to bring it back up to almost 14V is to rev the engine or start driving it.
It does the same thing when I switch on the A/C to MAX too.
It did this with the old Alternator so I replaced it with a 170A one but the Volt Meter still seems to be doing the same thing.
1. Is this Normal?
2. I'm not sure on which hose to install the "T" that comes with the Prestone Flush/Fill Kit. Standing directly in front of the motor and looking at the motor from the front you see two narrow hoses on each side of the top radiator hose on the thermostat housing. Is it the narrow hose on the furthest right (my right) or left?
3. At night when I switch on my dashlights, the GREEN RIGHT TURN SIGNAL is lit but not blinking. It will blink when I activate it. The left one is not lit but will come on lit and blink when I activate it and unlit when deactivated. What's causing this GREEN RIGHT TURN SIGNAL to be lit and how can I make it stay off like the left one?
4. My door locks (4 door) are wired into my aftermarket alarm so that when armed the doors lock. However, not all of them lock. The right and left rear pass doors stay unlocked. They are also difficult to lock manually from the inside by pressing the lever switch on each door. Do you think I have to open each door panel and lube them?
Thx, Phil
scorpio_vette
PostPosted: Tue Dec 13, 2005 2:14 pm    Post subject: Reply with quote
try hitting and kicking the dash. that's how i fix 90% of my electrical issues.
________
weed vaporizer
ILLXJ
PostPosted: Tue Dec 13, 2005 6:43 pm    Post subject: Reply with quote
The volt meter on my 96 does the same thing. I believe it is an issue with the grounds for the instrument panel. JIM.
________
Kent engine
