ZJ dual exhaust
Jeep Iceland
PostPosted: Sat Dec 17, 2005 1:26 pm    Post subject: ZJ dual exhaust Reply with quote
I removed the exhaust system including the cat and bougth a "dummy" for the sensor,anyone tried to install a full dual exhaust?
Twisted Evil
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Sat Dec 17, 2005 4:24 pm    Post subject: Reply with quote
I have ... The only way it would work is either ... Run them out in front of your rear tires... (Which puts them in a position to be crushed...) or remove your fuel tank and put a racing cell in the back.. Then there will be room to run the duals over the axle..
I know a very good muffler man and he said it could not be done ...
This is the same guy who did squeeze a set of dual exhaust on my Mitsubishi Montero Sport.. (As far as I know its the only one around with duals..) In fact people on the Mitsu forums told me it couldnt be done... Mr. Green
I extended my bump stops so that the pipes wouldnt get crushed and I had to move my tire from under the truck..(Its in the same position as the ZJ fuel tank..)
Sorry to be the bearer of bad news.. Neutral
Jeep Iceland
PostPosted: Sat Dec 17, 2005 4:43 pm    Post subject: Reply with quote
Mr. Green no bad news,you saved me from puting overload on my little gray cells rofl
F.D
1996 Limited 5.2
1976 Trans Am
