HELP!! 78 CJ-7, 304 problem
Huck Finn
PostPosted: Thu Dec 22, 2005 10:36 am    Post subject: HELP!! 78 CJ-7, 304 problem Reply with quote
I am reaching out hoping to cash in all the favors I have ever done for people (which have been a lot) with the hope I can get some diagnostic help.
I have a 78 CJ-7 with a 304. Everything is pretty much stock and I admit I am not much of a "wrench" but learning. My jeep idles fine but when I accelerate for approximately 1/4 to 1/2 of a mile it bogs down and sounds as if it has run out of fuel. I have had a retired mechanic friend of mine help me correct several things that we thought were the problems, but nothing has helped. We have relplaced the fuel pump and have acceptable pressure and volume. All fuel lines have been replaced as well as fuel filters. There is a new fuel tank, but the problem existed before the replacement. there does not appear to be any vacuum problem form the new tank and the gas cap. The carb has been re-built and the timing adjusted. The EGR valve has been relplaced as well. It idles fine but runs sluggish until it eventually dies. The distributor has been checked and appears fine. I believe, all types of engine pressures/vacuum have been checked and appear fine.
I wholeheartedly appreciate any input.
