What is a Leak Detect Pump?
DOUGNRENEES
PostPosted: Mon Jan 02, 2006 7:16 am    Post subject: What is a Leak Detect Pump? Reply with quote
I have a check engine light that comes up Leak Detect Pump Solenoid Circuit. What is this? I assume it has something to do with the emission control, but how do I fix or even check the problem?
PostPosted: Mon Jan 02, 2006 1:46 pm    Post subject: Reply with quote
The LDP applies vacuum to the fuel EVAP system to check for leaks. If it finds one, the computer trips the check engine light. 95% of the time, it's due to a loose or faulty gas cap.
If the cap turns out to be fine, replace the vacuum lines to and from the pump. Since the LDP can detect a leak from a hole as small as 0.040" you might visually inspect the hoses and not see a hole. So it's best to just replace them.
