Size of lift question
jscoto
PostPosted: Thu Dec 29, 2005 12:41 pm    Post subject: Size of lift question Reply with quote
I'd like to put a 3.5 inch BDS lift on my 1993 YJ, but I'm afraid it'll look wrong if I don't put on 33's. I'd rather not go 33's since I drive it 60 miles every day. Would 32's look 'normal' if I went this route.
Thanks for any opinions, Scott
onebadjeep
PostPosted: Thu Dec 29, 2005 12:59 pm    Post subject: Reply with quote
i think that the 32's would look fine on your rig with the 3.5 inch lift. before i built my jeep up i had a 4 inch procomp lift with 31's. they looked alittle small but it was fine. it will look really wierd with a body lift and only 32's so i wouldnt recommend doing that but its up to you. As you said its a daily driver so i would go to big with the tires.
hope that helps
"build it, break it, repeat"
91 yj
chrysler 318 "mopar or no car"
ax15
ford 8.8
procomp 35's
jscoto
PostPosted: Thu Dec 29, 2005 8:59 pm    Post subject: Reply with quote
Thanks for the reply. Basically my springs are flat so I'm looking to do something one way or the other. It's either OME or BDS, maybe superlift. Either way it's gonna be a better rig. I just wasn't sure which way to go. I think the 3.5 is the better route and the 32's---you thought so. Thanks for making my mind up!
