HOW REPAIR POWER WINDOW REGULATOR XJ 99 (VENEZUELA)
ottoborges
PostPosted: Wed Jan 04, 2006 3:39 pm    Post subject: HOW REPAIR POWER WINDOW REGULATOR XJ 99 (VENEZUELA) Reply with quote
The power regulator of Jeep Cherokee 1999 here in Venezuela isn’t nothing different to the installed in the XJ´s in the US , in fact is the same; the problems are the same…..
One year ago I changed the left one side, and 2 weeks ago right one side failed the same way…………..
Well, after to investigate in internet this problem…….I saw that everybody with XJ´s and WJ´s had the same problem……….and Chrysler didn’t want to resolve this problem…..You doesn’t idea how Chrysler work here in Venezuela……..!!!!!
Here in Venezuela the right power regulator cost 220$ and the left one cost 85$, I don’t understand why this difference ???even if both are the same but symmetries????. The only explanation that I can FIND is that Chrysler know the problem with this parts, in special the left one’s....by this reason they down the price....while the left side one they didn’t nothing……...
Once I understood the design problem......THE BROKE OF PLASTIC BRACKET THAT ATTACH THE ROPE STEEL to steel plate in regulator device ......I take the choice to fit it making one new support with one piece of aluminum……
Next......I show several pictures that I took when I was making the new piece in aluminum.....and of course the installation on the steel plate in the regulator device:
This is my work place!!
This pic shows how broke the regulator plate
This was my proyect with measures and everything!!
The aluminium piece began to change
It was very hard to make this litle holes!!
The steel rode found the new support
The steel plate found the newly the steel rode
The last step was to assembly the power regulator inside the riel and install inside the door!!!!
I hope tha this could help !!!!! Very Happy Mr. Green dancing banana
DIGITRUCK
PostPosted: Thu Jan 05, 2006 11:43 am    Post subject: Reply with quote
Hey Otto,
I would like to see what you've done but your links don't work.
Thx, Phil
ottoborges
PostPosted: Thu Jan 05, 2006 12:33 pm    Post subject: Reply with quote
You are right my friend, I don´t really know what happen with the pic´s.....I´ll need some help ......I think I didn´t put them right following the forum instructions!!!!
If you know how I can insert the pic´s I´ll be very happy!!
PostPosted: Thu Jan 05, 2006 12:41 pm    Post subject: Reply with quote
You need to find somewhere like imageshack or photobucket to host the photos. http://www.jeephorizons.com/phpbb/viewtopic.php?t=1495
DIGITRUCK
PostPosted: Thu Jan 05, 2006 11:23 pm    Post subject: Reply with quote
Hey Otto,
Donno why but now I can see your pix. Great work!
1. Question, so the little aluminum piece you made rides up/down on that metal rod/spring like thing that's driven by the motor?
2. Is that little piece all that you have to make to fix the Window Regulator? So you just drill a series of holes in it and the rod moves thru them like a worm gear to bring the window up/down?
3. Finally, how did you attach that little aluminum piece that you made to the Regulator Plate?
4. Is your Cherokee 2 Door or 4 Door?
Thx, Phil Very Happy
ottoborges
PostPosted: Fri Jan 06, 2006 4:57 am    Post subject: Reply with quote
Thanks Digitruk........Lastnight I could to fix the pic´s
A.- The little aluminum piece make the same work that broke plastic attach piece, it rides ud/dowm inside the metal way attached with the rod/spring.
A.- The little piece is all that you need to fix the window regulator....of course, you need cut the old plastic broke that attach the spring/rod.
3.-Finally, how did you attach that little aluminum piece that you made to the Regulator Plate?
A.- You need to drill the little aluminiun piece to attach it in the same hole near to old plastic broke.
A.- My Xj is 4 door but I´m sure that is work for 2 door too.
