Factory Subwoofer vs New Stereo
Jeep007
PostPosted: Sat Aug 06, 2005 5:51 pm    Post subject: Factory Subwoofer vs New Stereo Reply with quote
I have an 01 TJ Sport. It came with a factory Subwoofer under the center console. I thought it was time to install a new stereo. So I decided with a Kenwood 628 which plays MP3/WMA Sirius & iPOD ready. I didn't want to get to fancy, but store was out of lower end models.
OK, Everything is stock in thins thing. Front Right Left, Rear Right, Left & Subwoofer Speakers.
I was able to install the stereo and everything seemed to go fine, but now when I tested it out the subwoofer is not woofin. I checked the cable wiring layout and nothing indicates to have a special cable to the sub. So as far as I could see it is connected fine. What am I missing?
Anyone have this problem? How did you get it to work?
Thanks.
Oh and thanks to Quadna71. I was able to use his help guide from this site.
Jeep007[/b]
Shakin, not Stirred.
PostPosted: Sun Aug 07, 2005 6:49 am    Post subject: Reply with quote
Did you connect the turn-on lead for the sub unit to the remote turn-on lead coming off the head unit?
Jeep007
PostPosted: Sun Aug 07, 2005 2:30 pm    Post subject: Reply with quote
Where would I turn-on lead for the sub unit to the remote turn-on lead coming off the head unit?
Do you have pics or descriptions on what to look for?
I had the Kits which uses the the 2 factory connectors. Kinda looks like this in ascii art.
Jeep Connectors
Cables Cables
Brown [|||||||] Black [|||||||] <- Terminals Coming off Jeep
Brown {|||||||} Black {|||||||} <- Terminals Going to Stereo
{||||||||||||||} <- Stereo connector (Goes in Stereo)
Is this understanble
Jeep007
PostPosted: Sun Aug 07, 2005 3:30 pm    Post subject: Reply with quote
OK
I got. Thanks. I actually search your suggestion online and found the answer. I actually had 2 cables that could work. The Power Ant & Power Cont. It was the P.Cont. Thanks ehirner.
It's woofin again and there is a huge difference.
PostPosted: Mon Aug 08, 2005 12:48 pm    Post subject: Reply with quote
Jeep007 wrote:
OK
That's good to hear. I don't have the wiring diagram or colors handy so I was going to suggest Google for the schematic. But you found it.
You should do a writeup that we can post up here for further requests. Wiring colors, locations, etc. What connected to what. If you're interested. If not, ignore.
tigerr
PostPosted: Mon Jan 09, 2006 7:16 am    Post subject: Reply with quote
I'm wondering if anyone can post the info about wiring up the stock sub to an aftermarket deck.
Thanks.
John
