2000 Grand Cherokee heating problem. Stuck on defrost !!
nominds
PostPosted: Thu Nov 24, 2005 6:00 pm    Post subject: 2000 Grand Cherokee heating problem. Stuck on defrost !! Reply with quote
My cherokee seems to be stuck on defrost. i can't put the heat to the floor or to the vents, which with the cold weather my feet never get warm. does anyone know how to fix this or even get it to at least change to defrost and floor....i beleave the switch works because if i turn it to off it will stop.....please help...thanks
PostPosted: Thu Nov 24, 2005 8:13 pm    Post subject: Reply with quote
Check the blend door vacum line.. It is very thin line that runs into the fire wall on the outside... (its a hard plastic line very prone to breaking...)
When that line breaks it wont allow the blend door to open making everything blow thru the windshield vents..
That should fix you...
I can go and get a pic of mine if you need it..
Carl
nominds
PostPosted: Fri Nov 25, 2005 3:50 am    Post subject: Reply with quote
WOW......thanks a lot...its fixed.....the line was off on the engine block side......man my feet and i both thank u a lot !!!!!!!
PostPosted: Sat Nov 26, 2005 8:37 am    Post subject: Reply with quote
Glad I could help... Very Happy
Bluestrobes
PostPosted: Mon Jan 09, 2006 12:20 pm    Post subject: Reply with quote
You may want to put a tiny cable tie on the vacuum hose where it connects to the engine, I know mine kept falling off every few hundred miles
