new lift
PostPosted: Mon Jan 16, 2006 7:56 pm    Post subject: new lift Reply with quote
After talkin to swampy about what i would need im thinking of gettin 1.5-2 inch more lift...the coil spacers
i know i will need adjustable control arms and maybe some trimming to run 33s
anything else that i would need? someone asked if my shocks would be long enough. Would they?
also brakelines im sure they would need to be lengthend
anything else i may need?
PostPosted: Wed Jan 18, 2006 5:35 pm    Post subject: Reply with quote
Your brake lines wont need to be lengthend yet.. Take the bolt that holds the clamp to the inside of the front fender and pull the line out some.. Get a self tapping screw and bolt that brake line back on as low as you can.
Problem solved...Shocks will be fine till you break one then buy some new ones.. Mr. Green
PostPosted: Wed Jan 18, 2006 7:43 pm    Post subject: Reply with quote
haha alrite so everything else will be fine?
im asking lots of questions because i dont want to run into a problem i was unprepared for
i should be ok up front with the new alignment and finding longer sway bars and things like that?
are there anyproblems i mite even encounter i should concider?
