what tranny?
Gonzalo Medina
PostPosted: Fri Jan 20, 2006 11:27 am    Post subject: what tranny? Reply with quote
Does any one know of the 99 up grands 2wd models have the aw4 transmission?
PostPosted: Fri Jan 20, 2006 12:06 pm    Post subject: Reply with quote
The AW4 was only used in 93 ZJ's with the 4.0.
PostPosted: Fri Jan 20, 2006 7:13 pm    Post subject: Reply with quote
545RFE 5 spd. automatic transmission used in the 2001 - Current Model Jeep Grand Cherokee 4.7L engines
45RFE: 4 spd. automatic transmission used in 1999 - 2000 Jeep Grand Cherokees with 4.7L engines.
46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines.
44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines.
42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines
AX-15 5 spd. manual transmission used in 1993 - 94 Jeep Grand Cherokees with 4.0L engines
Gonzalo Medina
PostPosted: Sat Jan 21, 2006 11:35 am    Post subject: thanks Reply with quote
So which one is worthy enough to be called the aw4's little brother. I heard of grands having weak transmissions. My 93 grand has one and I have no complains, figuired they would just keep going with what's good. Looking to by a 99 up grand 2wd thanks....
