Sawmp Boy I got a question?
AKblue
PostPosted: Wed Jan 25, 2006 10:01 pm    Post subject: Sawmp Boy I got a question? Reply with quote
Swamp Boy wrote:
Not as old... 3.5 and 33's... With slightly trimmed fenders... Confused??:
Whats the width on the 33"s, and how much did you have to trim in the rear? Did you have extended bumpstops with this setup?
Doing 3.5 with 33x12.5 Thus night, charging batteries and buying blades and wheels for Friday fender cutting.
PostPosted: Thu Jan 26, 2006 10:01 am    Post subject: Reply with quote
gonna have to do some serious fender cutting and probably getting adjustable lower control arms for the rear to push the axle back out to center
swampy's the expert im just try to follow in his foot steps hahahaha
im sure he can explain it much better than I
PostPosted: Thu Jan 26, 2006 3:19 pm    Post subject: Reply with quote
They where 33X12.5 and I trimmed the fender up to the lip the first time.. (Thats the edge of the flat part of the fender ... And I had to trim the front of the back fender almost flush with the door sil... You will see what I mean...
Yes I put 2" bumpstop extensions and It still rubbed in the front a little ..
A little massaging the inner fender with a hammer solved that... Mr. Green
AKblue
PostPosted: Fri Jan 27, 2006 2:11 pm    Post subject: Reply with quote
Thanks for the info.
I have adjustable lowers and bumpstops. Also have a sawzall jigsaw and cutoff wheel, so I should be set. A BFH should clearance anything else.
PostPosted: Fri Jan 27, 2006 5:13 pm    Post subject: Reply with quote
Now you got it... Mr. Green
AKblue
PostPosted: Sat Jan 28, 2006 10:31 pm    Post subject: Reply with quote
With the lift and tires on I really get it.
Cutting that much on the front part of the rear fender, is that gonna have to be welded together? I can rivet it together until it can be welded if need be.
PostPosted: Sun Jan 29, 2006 11:30 am    Post subject: Reply with quote
what control arms are you using?
AKblue
PostPosted: Sun Jan 29, 2006 11:39 am    Post subject: Reply with quote
Stock uppers F/R, RE lowers only the rear is adjustable.
PostPosted: Sun Jan 29, 2006 1:41 pm    Post subject: Reply with quote
I welded mine ..But I guess its up to you.. I didnt leave enough of a lip to rivet.. Mr. Green
