Maybe my thermostat?
Keithtj
ARLI$$
ARLI$$
PostPosted: Sat Jan 28, 2006 2:47 pm    Post subject: Maybe my thermostat? Reply with quote
My temp gauge will reach the 260 degree mark, but as soon as I turn on the heater it drops to 210. It doesn't take any longer than 30 seconds for the temp to drop. I'm thinking that my thermostat may need to be replaced, but does anyone else have any other sugestions?
My Morning Jacket
TJ Apex
PostPosted: Sat Jan 28, 2006 10:41 pm    Post subject: Reply with quote
260 deg. that's hot! hopefully you didn't hurt somthing else, like the head and / or the head gasket.
I know some thermostat are designed to remain open when they fail, and if they do get stuck closed you'd know right away, It would get hot very fast and might even burst a hose or gasket.
Hopes this helps ya.
2002 Wrangler Apex
02' Apex Edition,
2" BB, 31" BFG AT's
WhatWasIThinkin
PostPosted: Sun Jan 29, 2006 4:44 am    Post subject: Reply with quote
IS this something that appeared overnight type thing or has it been steadily creeping up to 260*?
After you turn the heater on and it gets the cooler fluids from the heater core and lines, does it creep back up to 260* again?
If its a stuck open tstat. Ussually in winter if the temps are cooler where your at, it will run cool while driving and heat up only at stops or at idle. Unless of course the radiator is plugged with dirt. Ussually you will only overheat if driving on hot days were the radiator cant recover fast enough.
Another could be is the radiator cap is failing and isnt allowing the system to presurise, or maybe its time for a new radiator. Are you still running the factory one? They are well documented with failures after 5 years or so. Same goes for the water pump impeller. The impeller corodes or gets filled with enough gunk so that it cant move the water efficiently.
Probably start out with a pressure test and go from there.
Real Jeeps dont wear Bra's
Keithtj
ARLI$$
ARLI$$
PostPosted: Sun Jan 29, 2006 9:03 am    Post subject: Reply with quote
The radiator is only about 3 years old. Water pump was replaced about 4 3 years ago also, will the impeller be replaced with that? I didn't do the job and had a shop do it so I don't know.
When I turn the heater on it wont creep up to 260 again but sometimes it will hover in between 210 and 260 and then drop down to 210.
My Morning Jacket
Keithtj
ARLI$$
ARLI$$
PostPosted: Sat Feb 04, 2006 4:30 pm    Post subject: Reply with quote
replaced the thermostat and that fixed the problem!
My Morning Jacket
Lowrider
PostPosted: Sat Feb 04, 2006 9:31 pm    Post subject: Reply with quote
"Water pump was replaced about 4 3 years ago also..."
There's the problem. Water pumps never last 43 years. Mr. Green
She was only a fisherman's daughter,
But when she saw my rod she reeled.
2006 Wrangler Unlimited
1997 Cherokee Sport 2WD
Keithtj
ARLI$$
ARLI$$
PostPosted: Mon Feb 06, 2006 10:41 am    Post subject: Reply with quote
oops Embarassed meant 3 to 4 years ago Wink
My Morning Jacket
shotgun
PostPosted: Mon Feb 06, 2006 11:05 am    Post subject: Reply with quote
Also even though thermostats are designed to fail open, they can and will fail closed.
If you were tempted to just not put a thermostat back in , that can also cause problems. Without a thermostat your fluid cycles so fast that it can take forever to warm up causing more fuel to be used. Once it's hot it cycles too fast for radiator to work.
