Rubicon Unlimited Rattle
jeeppower203
PostPosted: Wed Feb 01, 2006 10:03 am    Post subject: Rubicon Unlimited Rattle Reply with quote
Hi All,
I have 2005 Rubicon Unlimited 6 spd. I've got 7k miles on it now and love it. I have an issue that I can't seem to figure out and was there when I drove it off the lot. When I go over a bump, I hear a rattle/thump. I've checked steering components and can't find anything loose. I brought to the dealer and they couldn't find anything either. Was wondering if anyone else has had this problem. I had a CJ7 with that had a loose clutch linkage that made a similar noise. Any ideas?
Thanks.
PostPosted: Wed Feb 01, 2006 10:16 am    Post subject: Reply with quote
Can you narrow down where it's coming from? Inside? Outside? Front? Back?
Moving this to the TJ section.
jeeppower203
PostPosted: Mon Feb 13, 2006 5:43 pm    Post subject: Front End Reply with quote
Definitely coming from the front end, possibly right under the driver side. Basically has to be either in some sort of steering or suspension component I think. Can feel it sometimes in the stearing wheel when turning and hitting bumps. Guess it could be suspension also. Was just wondering if anyone else had this sort of thing. Noticed a TSB for front end noise relating to steering on a rubicon unlimited but there wasn't much detailed information on what was actually wrong. Appreciate any feedback.
jeeppower203
PostPosted: Mon Feb 13, 2006 7:19 pm    Post subject: NHTSA Reply with quote
Just found this post at NHTSA and think this describes possibility. Will check with dealer about this. Any thoughts?
"PURCHASED 2005 WRANGLER RUBICON UNLIMITED ON JANUARY 14TH RETURNED VEHICLE TO DEALERSHIP FOR STEERING SHUDDER AND AWFUL FRONT END HANDLING ON JANUARY 17TH AND DEALERSHIP FOUND BAD STEERING STABILIZER FROM THE FACTORY.*AK "
jeeppower203
PostPosted: Fri Feb 24, 2006 1:56 pm    Post subject: Dealer found the problem Reply with quote
Brought to the dealer and apparently my rattle was from a bad clutch-brake assembly.
