shifter problem after body lift
Goto page 1, 2, 3  Next
97Wrang
PostPosted: Sun Feb 05, 2006 6:48 pm    Post subject: shifter problem after body lift Reply with quote
I installed a 3 inch body lift over the weekend and I'm waiting on some bolts that I ordered from jeep for the 4 wheel drive.
The problem is that when I was dryshifting it I noticed that besides the fact that the shifter is really low that it is also hitting the console when I shift into the lower gears, 2nd, 4th, and reverse. Anyone know how to fix this or had the same problem or similar one?
PostPosted: Sun Feb 05, 2006 7:54 pm    Post subject: Reply with quote
You want the answer you want to hear or the right way to fix it?
97Wrang
PostPosted: Sun Feb 05, 2006 8:15 pm    Post subject: Reply with quote
either one, i just want to fix it so i can drive it
KnightFire
PostPosted: Mon Feb 06, 2006 8:14 am    Post subject: Reply with quote
Well...either you'll have to custom make a shifter arm...or lower that body lift to about 1" and use a suspension lift to make up the rest.
Good Luck
KnightFire
2002 TJ Wrangler X
Patriot Blue 4.0L
Check Website for Mods/Photos
Amsoil Dealer
97Wrang
PostPosted: Mon Feb 06, 2006 4:33 pm    Post subject: Reply with quote
Anyone know if it is easy to move the center console back an inch or less?
Get Bent
PostPosted: Mon Feb 06, 2006 5:12 pm    Post subject: Reply with quote
Is it hitting the center console, or is it hitting the BODY underneath the center console (meaning, the transmission hump). Because it's pretty common for the shifter to actually hit the BODY after a 3" body lift (which is just another reason why most people avoid going any taller than 2", and many including myself just stick with 1"). If it's just hitting the console, then either modify your existing one (cutting the opening and buying a new shifter boot, or moving the entire console somehow) or buying a new one with a different design that doesn't interfere with the shifter.
Another common fix is to bend the shifter itself to reduce the angle and the amount it comes back.
But really, you need to check and see if it's hitting the BODY TUB itself, because modifying/moving the console won't solve that problem.
2
www.getbent4x4.com
97Wrang
PostPosted: Mon Feb 06, 2006 5:20 pm    Post subject: Reply with quote
Ya I went over and checked it and it is hitting the center console and not the tub.
Stevo02TJ
PostPosted: Mon Feb 06, 2006 5:40 pm    Post subject: Reply with quote
I had to drop my T-case (same effect bassically) and I had to take a foam sleeve off, and get a different style shift boot. Of course, my TC drop was maybe an 1" at the most!
Unless you drill your own holes, I don't think there is any way to move the console back...
...can you say dremel tool?
Either that, or take out the 3" BL and put in a 1" BL with a 2" Suspension Lift
97Wrang
PostPosted: Mon Feb 06, 2006 5:43 pm    Post subject: Reply with quote
I don't have the money to go with a suspension lift right now, because if im going to buy one its going to be for more than 2 inches. I think I'm just going to have to drill holes for moving the center console back. That seems to be the easiest way to do things right now.
PostPosted: Mon Feb 06, 2006 7:33 pm    Post subject: Reply with quote
if it was me i wouldnt modify my console if i was going to take out the body lift and replace it with suspension
why not just get a set of 30s and wheel it stock? I did that with my grand and it did alright and that was a grand, im sure you would be better off road than a stock grand
just my opinion
PostPosted: Mon Feb 06, 2006 8:05 pm    Post subject: Reply with quote
I'm surprised the kit didn't come with an extension for the shift lever. I helped install a 2" BL a couple of weeks ago and it came with one.
97Wrang
PostPosted: Mon Feb 06, 2006 8:10 pm    Post subject: Reply with quote
It came with an extension for the shifter itself but it comes back a little too far, im going to remove the foam on it that will give me a little more room, and then ill see where I am from there tomorrow night.
T.O.W. Vehicle
PostPosted: Tue Feb 07, 2006 5:10 am    Post subject: Reply with quote
A motor mount lift by 1" might help. Will have to relocate the fan shroud too.
Am I wrong to think body lifts over 1" are dangerous for highway use?
"T.O.W. "= Tent On Wheels.
Best Top Sailcloth RAT
RE 4.5"Super Flex Lift
AA HD SYE
JKS Quicker Disconnects
Shrockguards
PostPosted: Tue Feb 07, 2006 10:10 am    Post subject: Reply with quote
Well, they certainly aren't ideal. Wink
PostPosted: Tue Feb 07, 2006 7:14 pm    Post subject: Reply with quote
Hell all the stuff you are gonna have to re orginize becuase of this body lift is gonna be just as much work as install a suspension lift
Page 1 of 3
