Fender Flares
dlocke
PostPosted: Thu Feb 09, 2006 1:14 pm    Post subject: Fender Flares Reply with quote
I have searched here and all over the web regarding this. How do you remove these things? From what I can glean, you remove the nuts from the inside of the wheel tub (in other words, put a socket on the nut, turn, and snap the stud) and remove the assembly. I have an 88 XK and I need to remove the rear flares for some bodywork.
DJL
ILLXJ
PostPosted: Thu Feb 09, 2006 8:30 pm    Post subject: Reply with quote
That the way to do it. JIM.
________
full melt hash
PostPosted: Thu Feb 09, 2006 9:17 pm    Post subject: Reply with quote
Some of the the studs on the brackets will break when you remove the flares. I suppose you could go to the stealership and grab your ankles while they sell you new brackets. But what I did (before I removed the flares permanently) was drill out holes where the broken studs were and just got nuts and bolts to hold them on. It worked pretty well.
dlocke
PostPosted: Fri Feb 10, 2006 3:28 am    Post subject: Reply with quote
Thanks. That's what I'll do then. In fact, I'll leave them off so long as the tires don't extend past the wheel well.
DJL
