Overdrive Solienoid Problem
RussellRowell
PostPosted: Sat Mar 11, 2006 11:39 pm    Post subject: Overdrive Solienoid Problem Reply with quote
When its cold and once in a while when its hot, I can get the OD switch light to come on and it shifts out of overdrive. But most of the time, I can't get the light to come on. Changed out switch box-same issue.Thinking it might be the solienoid (hope not, expensive). Has anyone had any overdrive problems?
PostPosted: Sun Mar 12, 2006 3:25 pm    Post subject: Reply with quote
I looked in the transmission repair manual and it says to look for loose plug or wire... Trace it back and see what you find... If thats not the problem it very well may be your switch..
