Oil gauge
Shimma
PostPosted: Wed Apr 05, 2006 11:31 pm    Post subject: Oil gauge Reply with quote
My '96 Cherokee Sport oil gauge dosen't work,well it moves rapidly from left,to right off the gauge,lying horizontal,after the ignition is switched on!!?? It has been like it,since I bought it last week,the engine sounds fine,no abnormal noises,idles nicely,drives great,dipstick reading ok, so.... any ideas,please? cheers in advance...Jim
97XJ Jeeper
PostPosted: Thu Apr 06, 2006 1:04 am    Post subject: Reply with quote
have you checked to see if the wire has unplugged from the sending unit. that would be the first thing i would check.
two cents
JUST PUT IT IN 4X4 AND GO FOR IT!!!
Magnaflow high flow cat
FLOWMASTER SUPER 40
2 1/2" pipe cat back
Videos my XJ
http://youtube.com/profile?user=JeepXJJeeper
scorpio_vette
PostPosted: Thu Apr 06, 2006 7:30 am    Post subject: Reply with quote
i agree. check the plug and the little connectors inside. mine were worn out, so i used a pick and gently bent the little connectors so they would fit a little tighter and also replaced the oil pressure sender and that fixed it.
________
indica strains
Shimma
PostPosted: Thu Apr 06, 2006 8:02 am    Post subject: Reply with quote
Thanks guys,will check that out, appreciated,and I've just found the page in my Haynes manual with a picture of the unit...cheers...Jim
Shimma
PostPosted: Fri Apr 21, 2006 12:59 am    Post subject: Reply with quote
Yes it was the sender unit,but not the one as fitted originally!Someone had put a wrong sender in,only had the wires for the panel light?,not the original combined oil pressure/panel light,two sets of wires?well something like that,I can't remember exactly what my mechanic exactly said now,but the engine still had normal oil pressure, when he checked it with his garage tester gear.
So a new proper one is on its way......Update: now working fine!!Cheers... Jim
1996 Black Cherokee Sport 4.0
