Trans temp guage
PostPosted: Wed Feb 15, 2006 1:16 pm    Post subject: Trans temp guage Reply with quote
How would I install a trans temp guage in my grand?
42 Re trans, just wondering what fittings and stuff i would need and where to run the lines and where to have the sensor at
anyone have one installed?
Jeep Iceland
PostPosted: Wed Feb 15, 2006 2:02 pm    Post subject: Reply with quote
I have one istalled 4 inches from the return line of the cooler in front of the radiator,electrical sending unit.
This one is fine and has everything included http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D80212&N=115+4294925228+4294925227+4294822101+4294905502+4294908432&autoview=sku
Instructions http://static.summitracing.com/global/images/instructions/bmm-80212.pdf
F.D
1996 Limited 5.2
1976 Trans Am
Jeep Iceland
PostPosted: Wed Feb 15, 2006 2:06 pm    Post subject: Reply with quote
If only Mopar would have built a proper converter all our trannys would be fine,damn lockup band.
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Wed Feb 15, 2006 4:58 pm    Post subject: Reply with quote
Here is a nice way to mount it.
http://www.gaugepods.com/jeep.html
Stevo02TJ
PostPosted: Wed Feb 15, 2006 6:39 pm    Post subject: Reply with quote
*OFF TOPIC*
Is that the tach in the dash? haha, that's pretty neat
*ON TOPIC*
Foxx, I would say buy a single gauge pod...that looks like what this
tach is mounted in...then mount it to your dash, or down by the Shifter....or you could use a dremel and cut a hole if you have space...
HTH,
Stevo
PostPosted: Wed Feb 15, 2006 7:20 pm    Post subject: Reply with quote
yea mounting inside is not a problem just wondering how and where they mounted the lines and stuff
PostPosted: Wed Feb 15, 2006 7:22 pm    Post subject: Reply with quote
yea iceland your right...my tranny was fine damn torque converter but to be safe ill get a guage cheap insurance
can you take pics of where exactly you have your lines run and all that good stuff?
Jeep Iceland
PostPosted: Thu Feb 16, 2006 2:26 am    Post subject: Reply with quote
The lines are in stock location,I just cut the return line in front of the radiator,installed the T-fitting and just routed the wires to the gauge inside.
My gauge was actually broken but I ordered the one in I posted yesterday from summit.
But I can take a picture of the T fitting installed,will post it later today.
It's an electrical unit so there are no lines to install just the T-fitting and sensor and then just route the wires anywhere you like,we might have some trouble getting the wires inside the Jeep but I'm sure there's a way Mr. Green
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Thu Feb 16, 2006 8:01 am    Post subject: Reply with quote
alrite thanks that pic would be great if you get around to posting it if not i got the idea though
PostPosted: Thu Feb 16, 2006 8:24 am    Post subject: Reply with quote
Here's a writeup/pics on the installation of the B&M kit. It's in an XJ but it should still give you some ideas.
http://www.jeepin.com/features/tranny_temp_gauge/index.asp
PostPosted: Thu Feb 16, 2006 9:04 am    Post subject: Reply with quote
looks good thanks
