Tilt Steering Stuck
CheesyRider
PostPosted: Sat Feb 18, 2006 8:28 am    Post subject: Tilt Steering Stuck Reply with quote
Hi everyone! I'm a Jeep newbie!!
I just recently acquired a 1999 Jeep Cherokee. The steering wheel wont tilt. I was able to tell that the tilt lever is attached to a cable. I'm guessing that the cable has stretched or became loose at the other end , keeping the lock mechanism from disengaging.
Since I just bought the Jeep I don't have a repair manual yet. I figured someone here might know the answers to my questions:
Has anyone else here had the same problem, and how was it fixed.
What do I need to take apart so that I can inspect the cable and locking mechanism?
Thanks in advance!
CheesyRider
PostPosted: Sun Feb 19, 2006 9:10 pm    Post subject: Reply with quote
Well, I got it fixed.
I took off the plastic panel below the steering wheel, then the metal panel.
I removed the two nuts that hold the tilt adjustment mechanism in place.
I unhooked the cable that goes between the adjustment mechanims and the tilt lever.
I unhooked the bottom of the spring that keep the steering column from falling when the tilt lever is pulled.
I removed the nut that holds the adjusment mechanism to the steering column.
Then, I was able to remove the tilt mechanism.
I whacked it with a hammer a few times and it was good as new.
I reinstalled it and now my tilt steering works great.
I just love it whenever a repair involves whacking something with a hammer!!
PostPosted: Mon Feb 20, 2006 7:44 am    Post subject: Reply with quote
BFH... Never leave home without it... rofl
welcome
