Starting Problem
BlueSunday
PostPosted: Sun Feb 19, 2006 6:53 am    Post subject: Starting Problem Reply with quote
Ive got an '88 comanche automatic. The problem: When starting, the shifter obviously in the 'P' position, I crank the key full but nothing happens. Usually if i just play around with the shifter a bit itll start, i still dont even know if thats the problem, but it doesnt seem to be anything with the engine. It could be wiring or anything really. Just wondering if anyones had the same problem or knows how to fix it.
[img]http://www.imagestation.com/picture/sraid188/pb0cebfc8b7e3f58f76d433ca7a7247d5/f21772f7.jpg[/img]
JeepinNH
PostPosted: Sun Feb 19, 2006 12:50 pm    Post subject: starting Reply with quote
This is a typical issue. Go to this link, it will tell you what is needed. http://jeepin.com/features/nss/index.asp This is in the tech writeups. Lots of great info in there.
Mike
Present: 99 Cherokee
