Front Axle
gtouimet
PostPosted: Sun Feb 19, 2006 3:23 pm    Post subject: Front Axle Reply with quote
I have a 91 XJ with a D30 front axle. My question is can I pull my axle shafts and still drive it? It looks to me like it would not made a difference if they were there or not.
'91 XJ, 8" lift, 35x12.5x15 BFGs, 8.8, 4.56
PostPosted: Sun Feb 19, 2006 4:09 pm    Post subject: Reply with quote
You need to leave the outer stubs in place or your hubs will come apart and your wheels will fall off while driving.
It's a rather odd question you pose, why do you ask?
gtouimet
PostPosted: Mon Feb 20, 2006 9:14 am    Post subject: Reply with quote
When you say outer stubs does that mean the outer shaft between the u-joint a hub?
It is more off curiosity really.
PostPosted: Mon Feb 20, 2006 1:39 pm    Post subject: Reply with quote
Yes. That is the outer stub shaft. It actually passes through the hub and uses a large 36mm nut to hold it all together.
