Control arms?
PostPosted: Tue Feb 21, 2006 7:54 am    Post subject: Control arms? Reply with quote
When im driving, especially backing up out of a parkin spot or driveway and turning the wheels i get this popping from the front end....my guess is the control arms
anyone else have this problem? if so what was the fix?
aj173pa
PostPosted: Thu Feb 23, 2006 7:27 am    Post subject: Control Arms Reply with quote
I recently took a trip to Tennessee, and my jeep started popping and banging whenever I turned. It was the control arm.
Your sway bar is scrapping and banging against your frame.
The part you need is only about $20 from autozone.
one nut and one bolt is all you take off. On mine the control arm seperated in half.
When you take off the upper nut, the upper shaft has a slight taper and you half to beat on it to get it to pop out.
good luck....
PostPosted: Thu Feb 23, 2006 7:22 pm    Post subject: Reply with quote
which control arm was acting up on yours?
mine does it at slow turns, especially in reverse, and sometimes if i hit a bump the right way
PostPosted: Thu Feb 23, 2006 11:51 pm    Post subject: Reply with quote
My drivers uppper gets loose some times and I have to tighten it up..
Make sure they are all tight and your bushings are all in good shape..
PostPosted: Sun Feb 26, 2006 6:15 pm    Post subject: Reply with quote
control arms are good, stevo thought it was a u joint, so did dad...well sure enough looked at the ujoint on passenger side where the noise was coming from and one of the cups was rusted shut on the u joint got a new one and installed it and time to test it out....nope wasnt it
ended up being the wheel bearing that i purchased last week, took it back got another and so far so good, if it happens again im getting my money back
