awww nuts
dlocke
PostPosted: Tue Feb 21, 2006 3:46 pm    Post subject: awww nuts Reply with quote
I have removed the bumper on my 88 XJ as part of the restoration process. One of the bumper mounts was rusted out, so I purchased a couple new ones online. I knew I'd never be able to turn the bolts that hold the bumper mounts to the unibody, so I drilled into the heads to make snapping them off easier (and it did). I thought something was odd when the studs wouldn't pop out from the inside rear of the unibody. Took a closer look and found out why. . . the nuts are spot welded to the frame. Anyone have any suggestions or do I just have to get in there and grind the suckers out?
I am pulling the fuel tank when the weather gets a little warmer so that I don't blow myself up grinding and welding, so I should have better acces to the welded nuts.
DJL
JeepinNH
PostPosted: Wed Feb 22, 2006 7:12 am    Post subject: bummer Reply with quote
Too bad, these usually come out relatively well when lubed for awhile. Sounds like you need to grind or drill.
Mike
Present: 99 Cherokee
PostPosted: Wed Feb 22, 2006 7:26 am    Post subject: Reply with quote
Then tap new threads in the hole to the bolt size you need.
