99 XJ takes several seconds of cranking before engine starts
CheesyRider
PostPosted: Thu Feb 23, 2006 7:47 am    Post subject: 99 XJ takes several seconds of cranking before engine starts Reply with quote
I've got a 1999 Cherokee with 100,000 miles and a 4.0 engine.
It takes several second of cranking for the engine to start, but once it starts it runs fine.
The previous owner said his mechanic thought it was the injectors. Would bad injectors cause this? What other components should I check?
Thanks in advance for your help!
scorpio_vette
PostPosted: Mon Feb 27, 2006 10:53 am    Post subject: Reply with quote
try this.........turn the key to the ON position and wait 5-10 seconds. then try to start it. if it starts right away, then you know you have a problem with your fuel system not holding pressure.
after that you're on your own. i got lazy when i realized that, and now i just wait 5 seconds with the key on before starting it.
________
Suzuki Boulevard C109R history
RockOn
PostPosted: Tue Mar 14, 2006 9:34 pm    Post subject: Reply with quote
I have asked the same thing! (years ago)
my jeep along with all my friends jeeps that have the 4.0 seem to crank for several seconds before firing up
I was basically told that it was normal
89 or 90? XJ
majikxms
PostPosted: Wed Mar 15, 2006 5:25 am    Post subject: Reply with quote
Maybe on the older models (pre 90), but not on a 99 with 100k.
