97 ZJ No Engine Check Light/No Ignition
partguy
PostPosted: Sat Feb 25, 2006 2:11 pm    Post subject: 97 ZJ No Engine Check Light/No Ignition Reply with quote
greetings;
have a 97 grand cherokee 4.0 auto 4x4 with a sudden starting problem. engine spins fine but no spark. at no time with key on does CHECK ENGINE light display. when key is turned on fuel/voltmeters do not register any movement. manual key test for codes (on-off-on-off-on) yields nothing (odometer does show mileage though). check with obd2 tester on diagnostic port yields only repeated "no link" messages.
any suggestions would be greatly appreciated. i suspect perhaps a bad connection in the diagnostics, but all fuses and connections look fine.
thanks, ric nw of fsu
PostPosted: Sat Feb 25, 2006 5:32 pm    Post subject: Reply with quote
Is the fuel pump working????
Ignition switch is not an uncommon problem with Jeeps..
there is a test for the ignition switch and you can simply run a wire from the battery all the way to the fuel pump and see if the pump is working...
