how hard is it to remove the plastic side plating
newzj97jeeper
PostPosted: Wed Mar 01, 2006 10:16 pm    Post subject: how hard is it to remove the plastic side plating Reply with quote
since I painted my grille black. I am thinking of doing all the gray plastic on my zj the same color. I would perfure to remove it to paint, just not sure how to do it. Is any of the pieces screwed on or just clips?
keep it on the low end
nixt
PostPosted: Fri Mar 03, 2006 8:13 pm    Post subject: Reply with quote
If you were applying a line-x type material- I would definitely leave them on and just mask off around them; but then again I have never actually worked with real automobile paint.
nixt
JKS disconnects & Garmin GPS
Heavy duty OME Suspension kit
Life has No Value,
But Death Has Its Price.
newzj97jeeper
PostPosted: Fri Mar 03, 2006 10:29 pm    Post subject: Reply with quote
no I am going to be hittin it with a rattle can, it has kind of a textured finish to it. Ill take pics of my grille soon and try to get those up. looks kinda funny with a green ZJ black grille and gray trim.
RockOn
PostPosted: Sun Mar 05, 2006 7:53 am    Post subject: Reply with quote
a suggestion abou the rattle can, use bedliner
just scuff up real good, wipe down with degreaser & spray
I have a real good luck with bedliner sticking & looking good, most of all durable!
89 or 90? XJ
newzj97jeeper
PostPosted: Mon Mar 06, 2006 9:37 am    Post subject: Reply with quote
got the paint on, looks ok. But I am goin to spray them with bedliner today.
